Repainting WJ wheels - Page 2 - JeepForum.com
post #16 of 35 Old 05-13-2013, 09:19 PM
DavisI
They must not have sprayed it right. My wheels are plasti-dipped and they have been in mud and such and are fine. If they start to peel a bit, you can just respray that section with a few coats. Sanding the wheels before dipping them would defeat the purpose.
DavisI is offline
post #17 of 35 Old 05-13-2013, 09:30 PM
Jrboarder27
Originally Posted by scross1220 View Post
One run in the mud it will start to peel. I saw someone use it on their car and it started to peel after one car wash.
Understood and I believe you, but being able to remove it and undo a paint job is what makes it great. you cant really undo a sand job. being removable will give plasti dip limits.
Jrboarder27 is offline
post #18 of 35 Old 05-14-2013, 04:28 PM
Brakeman62
Great job!! What grit sand paper did you use before you painted and where did you get the new hubs??
Thx!
Brakeman62 is offline
post #19 of 35 Old 05-14-2013, 04:42 PM Thread Starter
scross1220
2012 WK
I use 150 to start with and finnish with 600 grit.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #20 of 35 Old 05-15-2013, 04:28 PM Thread Starter
scross1220
2012 WK
Final image with new hubs.
______ooooo
/__l_l_,\____\,___
post #21 of 35 Old 05-16-2013, 09:52 AM
bmandubj10
2003 WJ
I was thinking of going with plasti dip because my wheels are chrome and I have read it is hard to sand down the chrome evenly, I would rather sell all 5 rims and tires but I doubt it will be an easy sale. So I was just going to go black. Any advice you guys can give would be great. Thank you to og post your wheels look amazing sir good job!
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #22 of 35 Old 05-16-2013, 02:26 PM
CommanderWJ
They look great!
Any tips on removing small chips and rock rash?
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline
post #23 of 35 Old 05-16-2013, 04:36 PM Thread Starter
scross1220
2012 WK
Do you have an image of the wheel for me to look at? This will give me a better idea of what you have on it. Get a closeup of any damage as well. If its just clear coated then what I would do is clear the wheel and lightly sand the damage area with 600 and then 800 grit paper and reshoot the clear. If its painted I would fill the area with a filler agent and then sand with 800 grit and prime and paint. Chips are hard because its hard to blend the paint unless you have and exact color touchup paint. I have to redo my wheels one every 4 to 5 years.
______ooooo
/__l_l_,\____\,___
post #24 of 35 Old 05-16-2013, 07:15 PM Thread Starter
scross1220
2012 WK
Oh no my newly painted rim has a dent in it. When I went to have new tires installed today and the weight was removed from that spot there was a dent in the rim. Does anyone know if this is something I can hammer out? I will have to repaint the rim again I'm sure.
______ooooo
/__l_l_,\____\,___
post #25 of 35 Old 05-16-2013, 10:55 PM
CommanderWJ
I'm won't be close to my Jeep for the next week or so, but will upload as soon as I can. The wheels still have the factory clear coat on them, but they are looking a bit ragged with 12 years worth of ware and tear on them. Some of the scratshes an rock rash will probably need to be filled first, what can I use for filling? It seems like when the wheel gets damaged it sometimes leaves a ridge (some metal sticking up) so I will need to file/sand that down pretty good. I was thinking of pianting the wheels black/grey when I'm done sanding.
post #26 of 35 Old 05-31-2013, 02:34 AM
CommanderWJ
Hi, Sorry for the wait, I got round to taking some photos eventually. I hope to do some work on the spare tomorrow, it it turns out nicely I will move to the rest.
post #27 of 35 Old 06-02-2013, 11:33 PM
CommanderWJ
Here is my attempt from the weekend. I did the spare tire first, just to see how it turns out. All and all I pretty happy with how it came out, its my first time using spray paint so I do have a spot or 2 where the paint started to run a bit. Its not perfect, but its waaay better than it used to be!
post #28 of 35 Old 06-03-2013, 12:20 AM
pinky2252s
Looks good.
FYI, a deck of cheap playing cards works much better and faster for masking off the rim from the tire. Just air them down a bit and put the cards behind the bead.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #29 of 35 Old 06-03-2013, 07:43 AM
CommanderWJ
Thanks for the tip! I will try filling the scratches up first on my next attempt and see if it comes out better.
post #30 of 35 Old 06-03-2013, 08:17 AM
bmandubj10
2003 WJ
Looks good what kind of paint and primer did you use?
