Repainting WJ wheels - JeepForum.com
post #1 of 35 Old 04-30-2013, 03:28 PM Thread Starter
scross1220
2012 WK
And now let the painting begin! Today I started my restoration of my 2002 Jeep Grand Cherokee WJ wheels. Looks a lot better now don't you think. Here is the before shot.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #2 of 35 Old 04-30-2013, 03:28 PM Thread Starter
scross1220
2012 WK
Here is the after shot.
______ooooo
/__l_l_,\____\,___
post #3 of 35 Old 04-30-2013, 03:39 PM
lemiller
Nice job! It looks really good. What paint did you use?
lemiller is offline
post #4 of 35 Old 04-30-2013, 03:43 PM Thread Starter
scross1220
2012 WK
DupiColor. Three coats of silver and three coats of gloss. Will need to wet sand with 1500 grit in 7 days to to bring out the shine.
______ooooo
/__l_l_,\____\,___
post #5 of 35 Old 05-12-2013, 07:55 PM Thread Starter
scross1220
2012 WK
New hubs for the new wheels.
______ooooo
/__l_l_,\____\,___
post #6 of 35 Old 05-12-2013, 08:01 PM
WJ4x4LIFE
I love it!
WJ4x4LIFE is offline
post #7 of 35 Old 05-12-2013, 08:11 PM Thread Starter
scross1220
2012 WK
Fixing a burst SS brake line tomorrow and installing the hubs.
______ooooo
/__l_l_,\____\,___
post #8 of 35 Old 05-12-2013, 11:14 PM
Jeeples
Jeeples's Avatar
I couldn't help but notice that it looks like you painted over the wheel weight. The next time you have them rotated and balanced or new tires installed, there is going to be a nice sized chip in your finish.
I usually tell the tire shops to use stick on weights that are attached to inside barrel of the wheel. If they insist on using hammer on weights then I have them attached to the inside of the wheel. It helps prevent chips and marring in the factory clear coat on the face of the wheel.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #9 of 35 Old 05-13-2013, 08:51 AM Thread Starter
scross1220
2012 WK
You are right I did not think about that. Well I looks like in 3 years I will have to do a touchup or repaint the wheels when I have to change the tires again. No biggie but a very good point. I rember on my fathers car they put the weight on the inside of the rim like you said. He purchased an assortment of wheel weights online and had the tire shop do as you said. It looks a lot better to.
Thanks.
______ooooo
/__l_l_,\____\,___
post #10 of 35 Old 05-13-2013, 08:55 AM
bmandubj10
2003 WJ
Looks good I am thinking about painting my chrome rogues to plasti dip black since I have a white WJ and I hate chrome.
- 2003 WJ Limited 4.7L 4x4, 3 inch IRO coil lift with Bilstein shocks, OME .5 inch spacers, adjustable IRO Track Bar. Beefy Tenneco Steering Stabilizer. 32 inch General Grabber AT2's, 5000k DDM Tuning HID lights. Magna Flow Cat-back exhaust system. Rola safari rack. IRO bump stops. Kevin's Offroad 2 1/4 A-Arm spacer.
bmandubj10 is offline
post #11 of 35 Old 05-13-2013, 11:15 AM
Jeeples
Jeeples's Avatar
Thanks.
Hey, no problem, I've learned that the hard way too. Regardless, they look great
Jeeples is offline
post #12 of 35 Old 05-13-2013, 07:21 PM Thread Starter
scross1220
2012 WK
Thanks again for your advice. This is how I learn.
______ooooo
/__l_l_,\____\,___
post #13 of 35 Old 05-13-2013, 07:24 PM Thread Starter
scross1220
2012 WK
If you use Plasti Dip I would sand well. You are better off using a back engine paint from Dupi Color it will last longer.
______ooooo
/__l_l_,\____\,___
post #14 of 35 Old 05-13-2013, 10:00 PM
Jrboarder27
If your wanting to use plasti dip because you want to be able to remove it than don't sand it.
Jrboarder27 is offline
post #15 of 35 Old 05-13-2013, 10:10 PM Thread Starter
scross1220
2012 WK
One run in the mud it will start to peel. I saw someone use it on their car and it started to peel after one car wash.
______ooooo
/__l_l_,\____\,___
