I don't have pics but one bolt is on the back side (17mm IIRC) and one on the front at the top of it (15mm?). The bolt for the sensor is a 10mm. PLAN on it not coming out very easily. Go slow and wiggle it until it comes out. Tip, you will replace it eventually so add some silicone lube to the o-ring so it doesn't dry out and get stuck.
It was pretty eazy to do, once i found the bolt located on the back side of the starter and the bolt facing the engine it was a breez. Thanks for the help..
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
