Removing Rzeppa Driveshaft - JeepForum.com
post #1 of 7 Old 04-01-2011, 05:12 AM Thread Starter
metalfanatic
I just put a 2" budget boost on my WJ and now the front driveshaft is making alot of noise. I want to remove the rzeppa-rzeppa driveshaft so my question is does it just simply unbolt from the flanges or is there some special tool or instruction set?
2000 JGC Limited Blue, 4.7 V8, NV247, 2" BB, 5100 Bilsteins, LED Tail Lights, Projector Headlights
1985 CJ7 Red, 4.2 I6, Dana 300, 2.5 inch lift, 33 inch MT Baja's
metalfanatic is offline
post #2 of 7 Old 04-01-2011, 05:15 AM
FirefightinWJ
Nope, just unbolt it. Should be 8mm. Might need a hammer or a pry bar to knock it loose but it shouldn't take more than a few minutes.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #3 of 7 Old 04-01-2011, 05:46 AM Thread Starter
metalfanatic
Great! Thanks
post #4 of 7 Old 04-01-2011, 06:20 AM
volvite
It will help to have a pry bar to help remove it from the TC side first and then it will fall the rest of the way out. I did it on the side of the road in 10 minutes when mine finally failed. Good luck.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #5 of 7 Old 04-01-2011, 10:39 AM
victorito
good to know , mine just blow out! I have to take it out, a shop here (friend of mine) quoted me $100 buks for the double cardan style, full swap and ready to roll.
sweet!
hehe!
victorito is offline
post #6 of 7 Old 04-01-2011, 03:35 PM Thread Starter
metalfanatic
Wow! I got the driveshaft out with very little trouble and the rzeppa joint on the transfer case side was totally trashed(ripped boot, very little grease). I will be installing a carolina driveline shaft with u joints and flanges on each end. Unfortunately the 8mm bolts that came with the new driveshaft are 12pt versus the stock 6pt 8mm bolts. So, I'm off to Sears to get a 12pt 8mm socket so that I can finish the job. Thanks again for everyones help.
post #7 of 7 Old 04-01-2011, 07:59 PM
volvite
sweet!
hehe!
100 for the full swap is a dang good deal.
volvite is offline
removing pass. side cylinder head 4.7l without removing timing cover gdp WJ Grand Cherokee Forum 6 10-12-2014 06:55 PM
removing front driveshaft for gas mileage 08Z06 WJ Grand Cherokee Forum 18 03-16-2011 03:03 PM
Removing the drive line output yoke flange - front driveshaft. Jeep WJ 1999 GCL NOCARRIER WJ Grand Cherokee Forum 1 12-23-2010 05:54 AM
Removing front driveshaft in 2000 WJ soulmata WJ Grand Cherokee Forum 1 06-22-2010 07:44 PM
