Removing the rear seat head rests? - JeepForum.com
 1Likes
  • 1 Post By jeepsterpitt
post #1 of 15 Old 01-13-2011, 11:38 PM Thread Starter
HondaPeople
Okay... so short of using a Dremel tool with a cutting wheel, is there any way to remove the rear seat head rests? I use my Jeep for work and want to put a seat cover over the seat (the cover is not headrest friendly). I tried the little button that raises the headrests but they stop when they reach the top. I've pulled really hard, and nothing. Any ideas? Thanks!
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline
post #2 of 15 Old 01-14-2011, 12:42 AM
BransJeep
ther is two buttons one on each side, its not noticable but just look u will see it
-Brandon
4.0, 42re, 242
4.5 inch lift, front Ironman 4x4 adjustable CA's
RB1 and full J&L audio setup
Rola roof rack
BransJeep is offline
post #3 of 15 Old 01-14-2011, 01:08 AM Thread Starter
HondaPeople
There is one botton then a black latch at the base of the head rest which just folds the headrest forward. I checked the base of both sides and there is only one button. Hmmmm
post #4 of 15 Old 01-14-2011, 07:52 AM
mrJ
2002 KJ Liberty
mine on my 99 and 03 both pull all the way out. push the button where the headreast pole slides in and hold it in while you pull the headrest up and out. then pull the back seats up and forward, and you can fold the backrest section down and forward
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #5 of 15 Old 01-14-2011, 10:57 PM Thread Starter
HondaPeople
Yeah.... they're not coming out. Very frustrating. Thank you all for your input. Guess I will have to figure something else out.
post #6 of 15 Old 01-17-2011, 05:48 PM Thread Starter
HondaPeople
Yeah... I tried and tried. They don't come out. So I am going to Dremel them off--unless someone knows how to take the seat apart to release the latch that holds them in? Thanks!
post #7 of 15 Old 01-17-2011, 06:13 PM
Mr_Grumpy
They will come out but sometimes need a thump with something i found. I struggled to get one of mine off to fix the cover and i think i used a rolling pin or something similar to lever/thump it off.
Mr_Grumpy is offline
post #8 of 15 Old 01-17-2011, 07:47 PM
MStaffin
I could not figure it out too so I just fold them down lol. but my zj comes right out.
MStaffin is offline
post #9 of 15 Old 01-17-2011, 07:58 PM
jhc5
In my WJ (limited -- leather seats) they do come off. There is a button to push in on both headrest poles. Took me a minute to find the second one, because it is small.
jhc5 is offline
post #10 of 15 Old 01-17-2011, 08:02 PM
CarlJH
2003 WJ
when you pull the head rest up you will see the notches in the post have a shoulder cut it to them.
the last one on the bottom doesn't its just a straight notch. you kind of need three hands to sometimes get them out!
one to hold the catch in while you rock the head rest from side to side and pull up all at the same time.
CarlJH is online now
post #11 of 15 Old 01-17-2011, 08:15 PM
lloyd877
The clothe ones come off pretty easily. I leave mine out because they are kinda dorky looking being bigger than the front and all. They have little buttons that you just have to fiddle with it a little.
WJ 2001 4.0L
5.9 ZJ AKA Race Jeep 30" BFGoodrich ATs (Sold)
lloyd877 is offline
post #12 of 15 Old 06-29-2015, 12:51 PM
caleftridgejr
I need help in removing a backseat headrest in a 2011 jeep cherokee lard. The seatbelt is wrapped around the headrest and has frozen. I cannot gain enough slack to "reset " it
caleftridgejr is offline
post #13 of 15 Old 06-29-2015, 05:40 PM
Highschool_WJ
This is the 99-04 wj section, you'll want to check out the wk2 forum for a 2011
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #14 of 15 Old 06-29-2015, 05:59 PM
jeepsterpitt
if you dont push the hidden button it will not come off
99SK04GTX likes this.
jeepsterpitt is offline
post #15 of 15 Old 07-10-2017, 12:22 PM
Pheonix17
I have a 2000 jeep Cherokee Laredo and was trying to figure out the same dilemma, I figured out that if you pull the lever at the base of the cushion part of the head rest you can fold them forward and you can then fold the seats all the way down without having to remove the headrest completely
Pheonix17 is offline
removing pass. side cylinder head 4.7l without removing timing cover gdp WJ Grand Cherokee Forum 6 10-12-2014 06:55 PM
Removing Rear Bumper bjm9818 WJ Grand Cherokee Forum 4 09-09-2010 11:34 AM
Removing Rotors MikeFinn WJ Grand Cherokee Forum 7 08-25-2010 01:47 PM
removing rear skid plate xrattler WJ Grand Cherokee Forum 6 08-18-2010 07:30 AM
Front head restraint removable for seat cover? czshredd WJ Grand Cherokee Forum 0 07-17-2010 04:52 PM
