Removing front driveshaft in 2000 WJ - JeepForum.com
post #1 of 2 Old 06-22-2010, 06:39 PM Thread Starter
soulmata
Hello,
I recently acquired a 2000 GC Laredo, V8 4.7L. My first Jeep. I'm loving it so far and trying to work my way through some of the mechanical issues (212k miles).
One issue identified early on is that the front driveshaft is damaged or just worn as it has some play (you can freely rotate it about an inch either way). There's been an increasingly noisy vibration coming from underneath that I believe is probably the driveshaft (I have already ruled out the transmission, engine and tires as the source, and the rear differential fluid is clean and it doesn't heat up even after 800 miles).
Assuming this is the source of my noise, I was planning on removing it. If I remove the front driveshaft from this vehicle, for probably a week, will I experience any ill effects? I have been told that I shouldn't be concerned - that the transfer case won't leak and it will operate just fine as 2WD until I replace it. Is this correct?
soulmata is offline
post #2 of 2 Old 06-22-2010, 08:44 PM
Chris00WJ
You'll be fine. Ive been running without my front DS for many months with no ill effects.
Chris00WJ is offline
Why did removing the front driveshaft make MPG go crazy? Tbirdbassist ZJ Grand Cherokee Forum 8 08-02-2009 01:53 PM
removing front driveshaft mudslinger33 ZJ Grand Cherokee Forum 14 09-11-2008 03:43 PM
Need help removing Front Driveshaft jring.27 ZJ Grand Cherokee Forum 11 10-23-2007 08:07 PM
removing front driveshaft ? jeepunlimited ZJ Grand Cherokee Forum 4 02-05-2007 09:07 PM
2000 Front Driveshaft Death-Mobile ZJ Grand Cherokee Forum 1 10-03-2004 02:30 PM
