Remove timing gear on crankshaft? - JeepForum.com
post #1 of 6 Old 03-14-2014, 12:35 PM Thread Starter
jrandallc
A there a key holding it in, or is it just held on tight from sludge etc? The top camshaft gear came right off but I don't want to force the lower gear if it is being held on with a key.
jrandallc is offline
post #2 of 6 Old 03-14-2014, 01:47 PM
ChrisHager
Administrator
ChrisHager's Avatar
It should slip right off...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #3 of 6 Old 03-14-2014, 02:42 PM Thread Starter
jrandallc
It's not budging to come off. Would I be better off fighting it to get if off to put on the new gear, or just leave it and only replace the top gear and the chain? My gut tells me fix the issue but I'm making no progress with it.
post #4 of 6 Old 03-14-2014, 02:47 PM
ChrisHager
Administrator
ChrisHager's Avatar
I replaced both mine. I imagine you'll have a tough time replacing the chain without moving that sprocket. Maybe try some penetrating oil?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 6 Old 03-14-2014, 02:54 PM Thread Starter
jrandallc
It finally gave. Thanks for helping me stick with it. I've had penetrating oil soaking on it for over an hour so that may have helped it finally work loose.
post #6 of 6 Old 03-14-2014, 03:00 PM
ChrisHager
Administrator
ChrisHager's Avatar
Excellent!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
