-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Remove timing gear on crankshaft? (http://www.jeepforum.com/forum/f310/remove-timing-gear-crankshaft-2215617/)
jrandallc 03-14-2014 11:35 AM
A there a key holding it in, or is it just held on tight from sludge etc? The top camshaft gear came right off but I don't want to force the lower gear if it is being held on with a key.
ChrisHager 03-14-2014 12:47 PM
2 Attachment(s)
It should slip right off...
jrandallc 03-14-2014 01:42 PM
It's not budging to come off. Would I be better off fighting it to get if off to put on the new gear, or just leave it and only replace the top gear and the chain? My gut tells me fix the issue but I'm making no progress with it.
ChrisHager 03-14-2014 01:47 PM
2 Attachment(s)
I replaced both mine. I imagine you'll have a tough time replacing the chain without moving that sprocket. Maybe try some penetrating oil?
jrandallc 03-14-2014 01:54 PM
It finally gave. Thanks for helping me stick with it. I've had penetrating oil soaking on it for over an hour so that may have helped it finally work loose.
ChrisHager 03-14-2014 02:00 PM
2 Attachment(s)
Excellent! :thumbsup:
The time now is 05:02 PM.
