Remote Start & Keyless Entry ... VERY EASY! - Page 8 - JeepForum.com
post #106 of 337 Old 11-14-2013, 07:45 PM
Hlude1
Just ordered this for my 01 and going to do the install myself. Wondering if you cut and spliced the wires or if you used a connector like a scotch lock
Hlude1 is offline
post #107 of 337 Old 11-18-2013, 09:45 PM
Hlude1
alright just finished the install and everything seems to work, but jeep won't start on first try. It always has to wait for the second try. I noticed that the all lights come on with first start. Headlights and parking lights. On second start only parking lights. Everything seems to be wired correctly and everything else seems to work. Also on first attempt it cranks acts like it's going to fire and then cough instead
Hlude1 is offline
post #108 of 337 Old 11-24-2013, 07:30 PM
remmargorp
I just did this installation last weekend (2001 Jeep Grand Cherokee)... it definitely took me longer than 1.5 hours but I managed to do it while I was sick
I bought the Avital 4013 and ExpressKit DBALL from SonicElectronix, I asked if they could load the firmware for the DBALL and they did (confirmed by using an XKLOADER2), without affecting my delivery date (awesome)
Things worth noting:
  • I installed the Avital and DBALL behind the fuse box, I'm not thrilled with the location, it's tight... now that I've gone through the install, I would probably relocate to the center console area... would require a little more planning to get everything run/mounted there, but I think it could be cleaner then behind the fuse box
  • I did not ground PIN6 on the black 10-pin harness for the security system... this was not required per the DBALL Type 3 installation (which is for all Jeeps 99-04)... the stock security system functions properly
  • When using the remote starter the headlights will not come on until you press the brake to deactivate the Avital (key in ignition and on)... this caught me off-guard the first time I remote started at night
  • I would highly recommend installing a hood switch of some sort... unless you have the on/off toggle and trust that you'll always remember to turn it off when you're working on your vehicle... I installed a Directed 8601 magnetic switch... you have options... mechanical pin switch (hoodpin or doorpin), tilt switch, magnetic switch... keep in mind this switch should be Normally Closed... wire grey PIN4 on the 5-pin (H3, Remote Start) harness for the Avital 4013 to the switch then from the switch to ground
Connection notes:
  • I soldered almost all the connections, there were a few where I used a scotch-lok... I'll probably go back and solder the few connections I made with a scotch-lok
  • I soldered the ignition wires using the "Tap Soldering" method http://www.teamrocs.com/technical/pages/connections.htm
  • I used scotch-lok's for: the tap on the OBDII connection, the tap on the headlight wire, one ground tap to the main ground on the Avital 4103
  • I made interior grounds to the lower-left bolt (13mm?) on the firewall for the steering wheel
Thanks to the original poster for making this cut-and-dry!! All the info is found in the Avital 4103 and DBALL install manuals... but that initial post is fantastic!!
remmargorp is offline
post #109 of 337 Old 11-24-2013, 07:45 PM
Hlude1
I had asked sonic about loading the firmware and they said they didn't do that. I ended up ordering from 12voltsavings.com. It was cheaper and shipped two day priority mail for free. It was pre flashed and real easy to deal with them.
Hlude1 is offline
post #110 of 337 Old 11-24-2013, 09:32 PM
dadamets
[*]I installed the Avital and DBALL behind the fuse box, I'm not thrilled with the location, it's tight... now that I've gone through the install, I would probably relocate to the center console area... would require a little more planning to get everything run/mounted there, but I think it could be cleaner then behind the fuse box[*]I did not ground PIN6 on the black 10-pin harness for the security system... this was not required per the DBALL Type 3 installation (which is for all Jeeps 99-04)... the stock security system functions properly[*]When using the remote starter the headlights will not come on until you press the brake to deactivate the Avital (key in ignition and on)... this caught me off-guard the first time I remote started at night[*]I would highly recommend installing a hood switch of some sort... unless you have the on/off toggle and trust that you'll always remember to turn it off when you're working on your vehicle... I installed a Directed 8601 magnetic switch... you have options... mechanical pin switch (hoodpin or doorpin), tilt switch, magnetic switch... keep in mind this switch should be Normally Closed... wire grey PIN4 on the 5-pin (H3, Remote Start) harness for the Avital 4013 to the switch then from the switch to ground
Connection notes:
[*]I soldered almost all the connections, there were a few where I used a scotch-lok... I'll probably go back and solder the few connections I made with a scotch-lok[*]I soldered the ignition wires using the "Tap Soldering" method http://www.teamrocs.com/technical/pages/connections.htm[*]I used scotch-lok's for: the tap on the OBDII connection, the tap on the headlight wire, one ground tap to the main ground on the Avital 4103[*]I made interior grounds to the lower-left bolt (13mm?) on the firewall for the steering wheel
I have a question for you.... When you remote start and you have your heat and fan set to hi, does the fan go to hi when you remote start? I have a 02 Overland and when I go and get in the fan is not running... It will come on when I put the key in and depress the break.
Thanks in advance!
dadamets is offline
post #111 of 337 Old 11-25-2013, 12:11 AM
Thomahawk
Originally Posted by dadamets
I have a question for you.... When you remote start and you have your heat and fan set to hi, does the fan go to hi when you remote start? I have a 02 Overland and when I go and get in the fan is not running... It will come on when I put the key in and depress the break. Thanks in advance!
Put your temp as desired, fan and everything Ells on auto, then it will chill or heat your Jeep as needed.
Buildthread
Thomahawk is offline
post #112 of 337 Old 11-25-2013, 12:26 AM
dadamets
I did this tonight. 20 degrees f out and when I climbed in no fan running? I moved the fan speed dial and it started up?
dadamets is offline
post #113 of 337 Old 11-25-2013, 12:52 AM
Thomahawk
Does auto function Work as normal when you drive the Jeep?
Buildthread
post #114 of 337 Old 11-25-2013, 01:58 AM
dadamets
Yes, the auto function works fine as well as everything else when I drive the jeep.
dadamets is offline
post #115 of 337 Old 11-25-2013, 04:18 AM
briandor
Did you hook up the second accessory power input and outputs? The auto climate control runs on the second accessory circuit in the ignition switch and you'll need to hook up the second accessory input and output to power it. I just did a Viper in mine and had the same thing happening until I hooked up the second accessory power input.
briandor is offline
post #116 of 337 Old 11-25-2013, 06:04 AM
dadamets
As far as I know, I hooked up everything as the OP of this thread did. Now once in awhile, I will notice that the fan is running, when I get in to the jeep? Kind of stumped without going and checking all the wiring. Not sure when I will have time but I will have to do it. Now an odd thing happened last night, when I used the remote start...... When I got in the jeep, the fan wasn't running but the moonroof was open? Definitely stumped on this one!
dadamets is offline
post #117 of 337 Old 11-25-2013, 06:09 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
The auto climate control will do that. The fan will not go full blast if the motor is cold. One of the things I like about it. Its smart enough not to blast you with cold air until the motor warms up and it can blow hot air. Try it with the fan knob turned to full blast and the location knob to something other than auto. I'll bet it works just fine.
Edit: didn't see the part about the moonroof initially. That is completely unrelated to anything else, though.
~James
ezflip is offline
post #118 of 337 Old 11-25-2013, 06:16 AM
dadamets
I will have to do some testing. As far as the the moonroof???
Thanks for all the ideas!
dadamets is offline
post #119 of 337 Old 12-03-2013, 09:28 AM
ellenberger
I have a 2000 grand Cherokee and I want to install a remote start cause its my quad hauler and it sits down under my shed now since winters coming. I want to obviously be able to start it if I'm going to get it or just let it run for a bit on a weekend I dont use it. Its a good 100+ yards so my lazy a$$ isn't going in the cold to start and shut it off haha
So here's my question, I dont have a OEM remote, just a grey key. Can I still use this system and set it up to use the aftermarket key fob? Thanks!
ellenberger is offline
post #120 of 337 Old 12-03-2013, 10:37 AM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Yes. The OEM key fob would not be needed anyway.
rep-tile is offline
Keyless Entry Remote Replacement lilZeus WJ Grand Cherokee Forum 9 05-04-2015 11:16 AM
Remote keyless entry NeverL8 WJ Grand Cherokee Forum 15 04-07-2015 01:54 PM
Remote keyless entry range!!! TeeJay00 WJ Grand Cherokee Forum 11 08-18-2011 03:14 AM
keyless entry remote 00 limited mrjaydeeone WJ Grand Cherokee Forum 12 02-26-2011 09:49 PM
Program Remote Keyless Entry? WJChris WJ Grand Cherokee Forum 1 12-21-2010 10:45 PM
