Remote Start & Keyless Entry ... VERY EASY! - Page 5 - JeepForum.com
post #61 of 337 Old 02-05-2013, 08:21 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Originally Posted by Thomahawk View Post
Wire 2 wire
Which means what exactly, in this context? Sorry if thats a dumb question. Ive only installed one remote start and that was 15 years ago on an 89 corsica.
~James
ezflip is online now
post #62 of 337 Old 02-05-2013, 12:15 PM
Thomahawk
Ok no problem man,
wire2wire is litterly wires physicly conected together, instead of module that communication with another module via bus or wireless soluttions, they Are spliced up with old style wireing
Buildthread
Thomahawk is offline
post #63 of 337 Old 02-05-2013, 12:38 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Ok no problem man,
Okay that makes sense. I assume the alternative is the D2D which is mentioned earlier in this thread? What are the advantages and disadvantages of using one over the other? I know the model I got is D2D compatible and I also got the dball unit. But now I'm not sure which method would be appropriate for wiring it all. Thanks for your help, I'm kind of a noob when it comes to remote starts. I've done just about every other kind of wiring you can imagine, just not one of these.
~James
post #64 of 337 Old 02-05-2013, 12:53 PM
Thomahawk
When i did my install i was recomended by several pro alarm installers to do the w2w cause of all the hickups with the d2d systems, then you always 100% sure it Will work, the old good Way.
Buildthread
post #65 of 337 Old 02-05-2013, 02:18 PM
Bellator50
2011 WK
I'd installed it in the manner Ducati showed in my 2002 Jeep (D2D) for some reason my Jeep would shut down after a few seconds and none of the unlock functions worked. I went and installed it W2W and works flawlessly. W2W was also recommended to me due to reliability.
Bellator50 is offline
post #66 of 337 Old 02-06-2013, 04:31 PM
multmigs
2003 WJ
I'm in the middle of the install you did with the avital and Dball, seems like something is wrong though as the key programming part does not seem to work? I'm also sorta confused as to which button is the "programming" one as the valet button is also refered to the programming button in the Avital manual. I did the first part and the Dbal unit seems to take the programing correctly by changing its LED from orange to red but after that nothing happens when i try to turn the key to the ON position? Also not getting any door lock/unlock from the Avital remotes despite my OEM remote working fine and the Avital ones seem good as they perform remote start function normally??
Sounds like i have to do the W2W wiring method? I'm kinda bummed as I thought this would be done, and now my car is kinda useless until i work some more and meanwhile its 17 degrees all week...
multmigs is offline
post #67 of 337 Old 02-06-2013, 05:27 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Did you get the Chrysler firmware loaded on your DBALL?
~James
post #68 of 337 Old 02-06-2013, 06:11 PM
multmigs
2003 WJ
The place I bought it from said so. It was even hand writin on the box it came in
multmigs is offline
post #69 of 337 Old 02-07-2013, 08:41 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
[QUOTE
Avital Jeep or DBALL ( or Both )
H1/1 LIGHT GREEN/BLACK FACTORY ALARM DISARM N.U. (Not Used)
H1/2 GREEN/WHITE FACTORY REARM N.U.
H1/3 YELLOW (+) IGNITION OUT (TO ALARM) N.U.
H1/4 WHITE/BLUE (-) ACTIVATION INPUT N.U.
H1/5 ORANGE (-) GROUND WHEN LOCKED N.U.
H1/6 BROWN (-) HORN OUTPUT Optional Gray/Orange @ Horn Switch
H1/7 RED/WHITE (-) TRUNK RELEASE OUTPUT N.U.
H1/8 BLACK GROUND Chassis Ground
H1/9 WHITE (+/-) LIGHT FLASH ***Set to (+)*** DBALL 10 Pin, Pink/white
1 BLUE STATUS OUTPUT DBALL 10 Pin, Blue/White
2 ORANGE (-) ACCESSORY OUTPUT N.U.
3 PURPLE (-) STARTER OUTPUT N.U.
4 PINK (-) STARTER OUTPUT N.U.
1 PINK (+) (30 AMP) IGNITION CIRCUIT Dark Blue @ Ignition Harness & DBALL 10 Pin, Pink
2 PURPLE (+) (30 AMP) STARTER CIRCUIT Yellow @ Ignition Harness & DBALL 10 Pin, Violet
3 ORANGE (+) (30 AMP) ACCESSORY CIRCUIT Red/Black @ Ignition Harness
4 RED (+) (30A) HIGH CURRENT 12 INPUT Red @ Ignition Harness
5 PINK/WHITE (+) PROGRAMMED FOR ACCESSORY Black/Orange @ Ignition Harness
6 RED (+) (30A) HIGH CURRENT 12V INPUT Pink/Black @ Ignition Harness
1 BLUE (-) UNLOCK OUTPUT DBALL 10 Pin, Blue
2 EMPTY NOT USED
3 GREEN (-) LOCK OUTPUT DBALL 10 Pin, Green
H2/1 BLACK/WHITE (-) NEUTRAL SAFETY SWITCH INPUT Chassis Ground
H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE DBALL 12 Pin, Violet/White
H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE DBALL 12 Pin, Gray
H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE Hood Pin Switch
H2/5 BLUE/WHITE (-) 2ND STATUS/REAR DEFOG OUT N.U.
DBALL
14 Pin
Violet/Yellow Jeep OBD2 Pin 2
Yellow Jeep Sentry Module Pin 3, Dark Blue/White, Car Side
Orange/Yellow Jeep Sentry Module Pin 3, Dark Blue/White, Connector side
Red Jeep Pink/Black @ Ignition Harness
Black Jeep Chassis Ground
12 Pin
Violet/Green & Violet Brown Jeep Headlight Switch Connector, Pin 11, Yellow
The Avital has no use for the Door and Trunk Status Triggers.
Can anyone clean this list up for me a bit? I'm having a hard time understanding what is connected to what reading this? It looks like several wires are just being connected between the Avital unit and the Dball unit without connecting to some other wire in the car harness? others just connect from one unit or the other into the car wiring? I really don't want to give up on this but I'm semi afraid of screwing something up. I would also like to hook up the remote turn on feature for the rear defrost circuit and i don't understand how to do that either.?[/QUOTE]
I've got colored instructions for the dball unit I can't post up later when I get to my laptop. Or you can find them on xpresskit.com though they weren't the easiest thing to find on that site. That shows every connection that needs to be made, vehicle specific, between the dball and the jeep and the dball and the remote start unit.
~James
post #70 of 337 Old 02-07-2013, 10:28 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Here is the pdf download for the install instructions
http://www.xpresskit.com/DocumentDow...irmwareid=2491
~James
post #71 of 337 Old 02-08-2013, 07:02 AM
multmigs
2003 WJ
WOw thats a good link! too bad it wasn't on original post, makes the W2W install seem easy, i'm doing it this weekend.
Also i think it has been repeatedly asked and not answered how do you hook up the remote start to turn on the rear defrost circuit? I see the "aux" labeled circuit on the wiring instructions but don't think i have seen anyone address where to hook that up into the car?
multmigs is offline
post #72 of 337 Old 02-10-2013, 01:25 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Installed mine today. Did W2W. The only thing that doesn't work is the brake shutdown. I connected the brown wire from the Avital to the Grey wire on the DBALL 12 pin. But still a no go. I was going to rewire the brown directly to the brake switch, but I got impatient because those wires are a PITA to get to. So, Ill just use the remote to shut it down after I put the key in. Unless anyone has any other ideas?
~James
post #73 of 337 Old 02-11-2013, 07:14 AM
multmigs
2003 WJ
With the brake shutdown What does not work?
multmigs is offline
post #74 of 337 Old 02-11-2013, 09:03 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
The purpose of the brake shutdown is to shutdown the system when the brake is pressed. Mine does not. Pressing the brake does nothing.
~James
post #75 of 337 Old 02-11-2013, 10:33 AM
BLACK04WJ
I'm confused by this. once you put the key in and turn it to the on position, can't you just turn the key back to turn it off? I wouldn't think the brake shutdown would have anything to do with it.
I could be wrong though
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
Keyless Entry Remote Replacement lilZeus WJ Grand Cherokee Forum 9 05-04-2015 11:16 AM
Remote keyless entry NeverL8 WJ Grand Cherokee Forum 15 04-07-2015 01:54 PM
Remote keyless entry range!!! TeeJay00 WJ Grand Cherokee Forum 11 08-18-2011 03:14 AM
keyless entry remote 00 limited mrjaydeeone WJ Grand Cherokee Forum 12 02-26-2011 09:49 PM
Program Remote Keyless Entry? WJChris WJ Grand Cherokee Forum 1 12-21-2010 10:45 PM
