Remote Start & Keyless Entry ... VERY EASY! - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Remote Start & Keyless Entry ... VERY EASY!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Lifetime Warranty On All Savvy/Currie Suspensions and John
Unread 03-21-2012, 08:03 AM   #31
pushead
I just installed my second remote start on one of my cars. They are super easy to do as stated in these post. Just make sure you solder all your connections and get a good wiring diagram. Bulldog Security has about every diagram you can need on their webpage. You can also purchase a refurbed viper 5301 re for $99.00 if you google them. These are 2 way systems with a ton of features and a three year warranty. I love that I can check my car temp and turn on my rear defroster from a block away. I would recomend getting one of those light probes that tell you if the wire is a (-) or (+). That thing is a life saver. I know yo should use a multi meter but this is way easier.
P.S. I forgot to mention you may want to add a heavy gauge wire from the battery to under the dash with a few pig tails. This will make getting constant power allot easier. I have a 4 gauge wire running to a T-Block for my stero equipment I used for pig tails.
Its not a jeep if it dont have 4wd.
pushead is offline   Reply With Quote
Unread 03-21-2012, 09:46 AM   #32
compcrasher86
compcrasher86's Avatar
Coming from someone whos pretty experienced in installing remote starts, all the power you would need for a remote start is available through the ignition harness, not sure why you need an extra lead coming from the battery.
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
Unread 03-21-2012, 10:07 AM   #33
1AAdam
this looks like a great upgrade and it would probably be worth doing!
Adam
1aauto.com
888-844-3393
1AAdam is offline   Reply With Quote
Unread 03-21-2012, 10:14 AM   #34
pushead
So your not hacking into existing lines and adding an extra strain on them. I agree it's not needed but if you want to do it properly vs a hack and tap you should. Which is another reason I do my own installs. I would even bet it say's it in every installation book for any security unit.
Unread 03-21-2012, 10:37 AM   #35
jerrod710
2003 WJ
Subscribed. To the OP, how does the system you bought and installed compare to the Viper Systems?
jerrod710 is offline   Reply With Quote
Unread 03-21-2012, 12:19 PM   #36
pushead
Do a google search on them. There are two kinds of remote starters. 2 way and a 1 way. They all can have a few diffrent features.
With a 2 way your remote has more options like providing the inside temperature of the car, a confirmation tone the signal was recieved and activated what you selected and a few other gadgety things.
Viper is just a name brand and the model I suggested is the 5301 Responder LE.
Unread 03-21-2012, 12:33 PM   #37
jerrod710
2003 WJ
Will do. Thanks.
Unread 03-22-2012, 11:59 AM   #38
tjlmbklr
Originally Posted by ducatiguynyc View Post
I almost forgot... My review of the system itself!
The Avital 4103 in conjunction with the DBALL module works flawlessly! Install and programming, as you can see from the above post, was a snap. Everything works as it should, and the range on the unit far exceeds that of the OEM key FOB.
Price wise, I was quoted $350 from local sound / alarm shops and as high as $450 from the "big box" chains to have the same (or similar) system installed.
So for $125 and the 1.5 hrs it took to install and setup it up, I have ZERO complaints!
What would you say the range is? I read a review on Amazon that said he can't even start his from 20' standing on his porch.
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline   Reply With Quote
Unread 03-22-2012, 01:24 PM   #39
compcrasher86
My Magnavox system, based on Avital, does way better than 20 feet. The video speaks for itself.
Build Thread
RIT Offroaders
Matt
Unread 03-22-2012, 02:26 PM   #40
jerrod710
2003 WJ
Video Link: www.youtube.com/watch?v=Yz8ArMPTVoc
Where was the vehicle?
Unread 03-23-2012, 05:06 PM   #41
ducatiguynyc
If the guy on Amazon can't start his from 20', then he probably didn't hook up the included antenna, or if he did, it's possible the line got pinched, cut, or he's got a bad antenna module.
I can't put a exact number range in terms of how far the system works from, as it will vary from location to location, but I myself have started my car from inside my office (brick, 2 story building) with the car parked at minimum 200+ feet away, maybe even further.
ducatiguynyc is offline   Reply With Quote
Unread 06-27-2012, 10:20 AM   #42
nor7cal7
I got a couple questions to the original poster. So I changed out my passenger door window/lock control module because mine was shot. I got a used one out of a freedom edition. I never gr my comp reprogrammed so my key fobs would work because the dealer wants like 90 bucks. I figured that I would just do this install instead. These combined units bypass that passenger door module correct? So my lock unlock will run out of the new avitol system not the factory door module. So I don't need to get my door module reprogrammed by the dealer?
"Don't tread on me!"
nor7cal7 is offline   Reply With Quote
Unread 11-04-2012, 06:58 PM   #43
Varnish
Moab dreamin'
Varnish's Avatar
Hey guys, I thought I would share with you all my remote start experience on my 2004 Jeep Grand Cherokee....
Total install time... 1.5 hrs
Good luck and enjoy!
Thank you so much for this write up. I ordered the Avital 4103lxl, xpresskit dball, and Xkloader2 off amazon. Took me a few hours to go over and double check the connections with the models I got and my 99 grand Cherokee but everything checked out and during the install I just followed your steps exactly. Awesome write up for the forum!
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
Varnish is offline   Reply With Quote
Unread 11-05-2012, 02:12 AM   #44
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Hi man, i am about to install a Viper remote start, but i am a bit unsure where to trigger the rear defogger relay, can you pls tell me how you hooked up this feature. Did you tap into black/white wire going from JB to rear defogger or into 86 at rear defogger relay, i got different soluttions recomended,(from Ppl that didnt wire that feature) but i want to be sure, THANKS.
2000 Grand Cherokee Limited ¤ 4.7 Low output V8 ¤ 545RFE ¤ Quadradrive ¤ Shale Green Metallic ¤ Agate/Carbon interior ¤ Viper 5704 alarm/remote start ¤ Alpine HU ¤ Rockford Fosgate P500-4 +P500-1bd ¤ 4X Infinity Kappa 60.9CS +1X 100.9W ¤ Rugged Ridge floor mats ¤ LED interior light ¤ Tinted windows ¤ Grill mesh mod ¤ Spyder halo headlights ¤ Spyder halo foglights ¤ 6" Hella`s 500 Black magic Lights ¤ Debadged ¤ Rear Wiper Delete ¤ Spyder LED taillights ¤ Smoked LED third brakelight ¤ LED licence plate light ¤ Saguaro 3/4in recovery shackles ¤ 3" Kolak exhaust Magnaflow cat Flowmaster 70 muffler ¤ Superchip ¤ TM snip mod ¤ 2" BDS springs ¤ Bilstein 5100 shocks ¤ Addco swaybars ¤ JKS trackbar ¤ JKS front discos ¤ IRO rear ext endlinks ¤ Moog super trial boss SS ¤ BTF Cryptonite diffcovers ¤ Stillen Rotors/Black matrix pads ¤ Pro Comp 17`s Helldorado Machined polished w/General Grabber AT2 255/70/17 ¤ JK Sahara 18`s w/Nokian Hakkapelitta R SUV 255/60/18 ¤ Urban Assault Vehicle
We dont care how they do it in Japan!
Buildthread ¤ http://www.jeepforum.com/forum/f197/...orway-1193503/ ¤
Thomahawk is offline   Reply With Quote
Unread 11-18-2012, 08:43 AM   #45
multmigs
2003 WJ
has anyone installed one of these systems and used their factory key left inside the dash area to defeat the programmed key necessity? There are numerous threads where people do that to avoid having to pay for the dealer cost of programming keys as well as the much lower cost of standard key blanks? I realize that this move is not good if you are concerned about security.
multmigs is offline   Reply With Quote
