Redline heavy shock proof rear diff? - JeepForum.com
post #1 of 8 Old 08-06-2013, 10:22 PM Thread Starter
WJ03_Overland
2006 WK
Has anyone ever used this fluid in their rear ends? A few of my track cars also call for 75W140 in the rear end but everyone seems to gravitate toward the redline fluid. The fluid has film thickness is 75w250 but the actual friction is equal to 75w90. Please don't flame the post as I am new to Jeeps. Just thinking of alternatives or possibly some one has experience running it.
-Chris
WJ03_Overland is offline
post #2 of 8 Old 08-07-2013, 12:39 AM
Thomahawk
Sorry, njet, 75W-140 is the correct fluid.
Buildthread
Thomahawk is offline
post #3 of 8 Old 08-07-2013, 12:45 AM
alfaitalia
The numbers refer to viscosity (thickness) not friction level.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #4 of 8 Old 08-07-2013, 03:48 PM Thread Starter
WJ03_Overland
2006 WK
I probably worded the question bad. Sorry for misleading. I understand the fluid dynamics and the SAE liquid numbering system. Being that it "protects" as a 75w250 but only puts "strain" of 75W90 has anybody ran it? Ive read a few threads using search but its all bickering over what fluid is better blah blah, basically all opinion. Just asking for feedback if someone out there has.
post #5 of 8 Old 08-07-2013, 06:17 PM
rm2001wj
rm2001wj's Avatar
Can you give a web source for your "protection" and friction or "strain" numbers? I would like to have a better understanding of what they mean.
rm2001wj is offline
post #6 of 8 Old 08-07-2013, 07:35 PM Thread Starter
WJ03_Overland
2006 WK
post #7 of 8 Old 08-07-2013, 09:32 PM
rm2001wj
rm2001wj's Avatar
Using that link, I found this statement:
Avoid use with pumps, coolers, and filters as unique medium and affinity for metal can cause clogging
If your Overland has Quadra-Drive, then it has Vari-Loc differentials. These are limited slip differentials which use a gerotor pump/clutch pack system for limiting the slip of one of the wheels on the axle. If for no other reason, it seems to me that having the gerotor pumps means that gear lube should be avoided.
rm2001wj is offline
post #8 of 8 Old 08-07-2013, 09:43 PM Thread Starter
WJ03_Overland
2006 WK
OK that was were I was asking for more info. Being a "car guy" and new im still learning. I have yet to fully read into the chain drives of the transfer cases nor the dana 44/30 axles. I appreciate the help and info!
