red cable on alternator always hot - JeepForum.com
post #1 of 18 Old 01-25-2014, 11:36 AM Thread Starter
AliAbed
Wj red cable on alternator always hot
Hi guys what is the problem that make the red thick cable on the alternator always hot
AliAbed is offline
post #2 of 18 Old 01-25-2014, 11:42 AM
jbaldry
Are you pulling a lot of power? Subwoofer? Auxiliary lights? Big audio set up? Is your battery holding a charge well?
2000 Jeep Grand Cherokee Limited, Quadradrive, 4.7 V8
Living life mod by mod
jbaldry is offline
post #3 of 18 Old 01-25-2014, 11:51 AM
MadderThanMax
Bad Earth Mate!! Check all earths including starter..Heat in the cable = resistance or load.
MadderThanMax is offline
post #4 of 18 Old 01-25-2014, 03:25 PM Thread Starter
AliAbed
Thanks guys, Its just a stock jeep with original equipments, No big loads,I buy a new battery and the alternator charge very well.where are the main earths cable locate.can bad rectifier make heat in the cable.
AliAbed is offline
post #5 of 18 Old 01-26-2014, 08:43 AM Thread Starter
AliAbed
AliAbed is offline
post #6 of 18 Old 01-26-2014, 10:57 AM
Thomahawk
^^^X2 check all your grounds and main power wire conections.
Buildthread
Thomahawk is offline
post #7 of 18 Old 01-26-2014, 11:30 AM
MadderThanMax
Wj
Yer Vote of Confidence is appreciated Lols!
post #8 of 18 Old 01-26-2014, 11:36 AM
MadderThanMax
Best way to check bad earth is to follow the earth cable from the negative side of the battery down.
IMHO ONLY earth cable is either BLACK or BROWN pending on manufacturer.. so for instance on the starter there will be a red (Live OR + )and in general the opposite is BLACK/BROWN on the opposite terminal.
Re reading your post, clean the terminals on the alternator and re tighten and advise.
A photo may also help..
post #9 of 18 Old 01-26-2014, 03:04 PM Thread Starter
AliAbed
Thank you all
AliAbed is offline
post #10 of 18 Old 01-26-2014, 03:16 PM
MadderThanMax
Yer welcome, that's what we come here for...
post #11 of 18 Old 01-26-2014, 06:09 PM Thread Starter
AliAbed
thank you a lot my friend i will swap and change this wire soon,IF I had a bad ground strap wire could this poor connection lead some sensors to work bad like knock sensor with code p0325
AliAbed is offline
post #12 of 18 Old 01-27-2014, 02:27 AM
MadderThanMax
It's possible yes..it can knock a lot of things out.. I had a car that had a bad MAF (Mass Air Flow Meter) once was looking at a 500+ repair bill.. was told that it needed various parts including MAF. So I traded it for another.. afew weeks later there's my car gleaming on the forecourt. I asked the mechanic what was wrong.. changed out everything, coil packs, sensors, MAF, Lamba Probes (O2 Sensor) the lot, causing a lot of chaos & confusion ..his mate came over for a look and ask what was a wire that was supposed to be attached to the chassis leg doing hanging?? One new earth cable later and car was as good as new so I'm told..old one had corroded through.. So Yes, in effect it could..
post #13 of 18 Old 01-27-2014, 06:57 AM
Matrixxxx
2005 WK
The heat is caused by current flow, i would have thought if you have a bad earth it would limit the flow of current and some things wouldn't work (ohms law- increase in resistance lowers the current at a fixed voltage). the charge alternator is capable of putting out a lot of current , you need to put a clamp amp meter on the cable and see how much current is flowing. it may be normal. when you say hot, how hot , power cables are usually ok up to 80 degC then the insulation starts to melt.
Matrixxxx is offline
post #14 of 18 Old 01-27-2014, 05:51 PM Thread Starter
AliAbed
Thanks Matrixx its burn and melt only the black cap on the alternator
AliAbed is offline
post #15 of 18 Old 01-27-2014, 07:34 PM
doityourselfMM
doityourselfMM's Avatar
Just to appease my curiousity, the next time you feel the hot red cable at the alternator, can you also feel the red and black cables at the battery side?
doityourselfMM is offline
