recurring axle seal leak? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > recurring axle seal leak?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREELifetime LED on Sale at Baseline 4x4 Outfitters LED Light
Unread 06-08-2010, 07:03 AM   #1
davets
1956 CJ5
Rear axle seal on my 2002 WJ, dana 35 keeps leaking. shop replaced it 3 times and the last time it got new bearings. They say they don't see any reason for the repeated leak. I bought an axle from the junkyard that's loaded with bearing and all. I've never seen a setup like this before. I can't spin the seal freely as it sits on this junkyard axle. Can someone explain to me how this seal works? Does it spin in the tube and if not how does it work? Can I press off the bearing retainer or does it need to be drilled and broken?
*** 1956 CJ-5, milled head,elec fan,power steering,4-whl discs,rubber mounted cage,all drivetrain and engine incl distributor vented into firewall,Saturn overdrive,Lockrites,Rezeppa joints,2 1/2" springs arched add'l 1 1/2", homemade expanding shackles,reinforced frame,glass tub, stainless tank, 31X15.5 Terras on 15x10 and 15X12 rims-trail, 31X10.5 A/T's on 15X10 alum rims-street,Amsoil.
davets is offline   Reply With Quote
Unread 06-08-2010, 07:46 AM   #2
88yjproject
It spins on the Axle tube. Your axle shaft might be pitted causing the leak to repeat. I would look at it and see.
88yjproject is offline   Reply With Quote
