Recovery D-rings in place of WJ tow hooks? - JeepForum.com
post #1 of 15 Old 12-06-2013, 09:40 AM Thread Starter
oof_da
I DID search, but didn't find a mention of a recovery D-ring that would bolt in place of the front tow hooks on my '04 Overland. I'm glad they're there, but just looking at them, I don't like the fact that they're open to allow a slack cable or rope to drop off.
Does anyone make a D-ring that will bolt in place? Lot's of D-rings out there, but any I've found are just the ring and pin, not any lug portion.
oof_da is offline
post #2 of 15 Old 12-06-2013, 10:08 AM
kaestacrunch
Fawkes Fabrication makes great quality stuff. Saguaro (I believe that's the name?) makes a similar product, but I haven't used them, so I can't say.
kaestacrunch is offline
post #3 of 15 Old 12-06-2013, 11:54 AM
Tollmtn
Three options, I took of my Overland hooks and used a variation of the third option, actually a hole drilled through my winch mounting plate for a shackle.
1. There are bolt on and weld on D-rings available at about any rigging company. The problem is for some reason Jeep drilled the two OEM mounting bolt hole side by side instead of length wise to the Jeep like they should have been. So to have a D ring mounted work wise you either have to drill new holes or better yet weld it on. http://www.uscargocontrol.com/Ratche...-Mounting-Ring
2. You can make a strap retainer clip for your oem hooks like in this thread http://www.jeepforum.com/forum/f310/...clips-1455009/
3. Or make a replacement out of 3/8" or 1/2" flat bar like in the picture, the pictured one is on a different brand 4X4.
Tollmtn is offline
post #4 of 15 Old 12-06-2013, 01:47 PM
Olese
Saguaro use to make really nice ones, I have them on my WJ but they were bought out or something by a company called Alpine something. I looked around and couldn't find their website, they may have gone under but they took over Saguaro and then made the much thinner, not as beefy as Saguaro.
The pic at the top are the Saguaro's on my WJ and the bottom pic are the Alpine's.
Olese is offline
post #5 of 15 Old 12-06-2013, 02:08 PM
ChrisHager
Administrator
ChrisHager's Avatar
New and in-stock: WJ shackle tabs for $125
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #6 of 15 Old 12-06-2013, 04:15 PM
platinum5.9
2003 WJ
Originally Posted by ChrisHager View Post
I have these and absolutely love them. I would recommend them to anyone. I've used them to winch on and no problems at all!!
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #7 of 15 Old 12-12-2013, 08:23 AM
Fawkes
WJ recovery gear
Fawkes's Avatar
Aspen Creek (the company that bought out Saguaro) appears to have gone under, so it looks like we now stand alone (pun intended) in the WJ shackle-tab department.
Kris Fox
Fawkes is offline
post #8 of 15 Old 12-12-2013, 08:31 AM
ChrisHager
Administrator
ChrisHager's Avatar
Advertise that stuff! Now's an awesome time to make a few bucks. Christmas sale?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 15 Old 12-12-2013, 08:53 AM
fast540
I keep a roll of black vinyl tape in the jeep and just puta couple wraps around the strap and hook to keep it from slipping off
fast540 is offline
post #10 of 15 Old 12-12-2013, 08:53 AM
texlurch
And they make great front rock sliders too!!!
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #11 of 15 Old 12-12-2013, 08:11 PM
Fawkes
WJ recovery gear
Fawkes's Avatar
While they're meant for pulling, I guess they can take a bump or two.
There are threads up in the vendor display forum, but I hate spamming them to keep them up on the first page. As far as "sales" I wish I could afford to discount anything. As it is, prices will be going up in 2014.
Kris Fox
Fawkes is offline
post #12 of 15 Old 12-12-2013, 08:17 PM
PowderHound
2003 WJ
I would be in the fawking club, but found some overland hooks a week before I found out about you Kris. They are way better than the upside down hooks lol.
2003 WJ♦Inferno Red Limited(4.7 H.O., Vari-Lok axles)♦OME HD/BILLY 5100S♦IRO t-case skid, adj. tb, sway links♦Moog SS♦Factory tow package w/harness & tow hooks♦ Amp/12 sub box♦new bad b**ch passenger♦1993 XJ country♦lift/muds/winchbumper-sold♦build thread instead of long A$$ sig soon...
PowderHound is offline
post #13 of 15 Old 12-13-2013, 06:08 AM
ChrisHager
Administrator
ChrisHager's Avatar
I bought hooks before Fawkes was making these. I wish I had the front receiver with the D-ring mounts! If only I had waited! :-)
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #14 of 15 Old 12-13-2013, 05:23 PM
mycreativename
Not to talk down the shackles at all (trust me, I've thought about getting them time and time again cause I like them so much, hah), but I have a simple solution to your straps falling off the hooks issue. I was getting similarly frustrated and actually ripped an eye end of a strap because it halfway-fell off the hook and the hook went right through it. I always have a couple of those produce rubber bands (the ones that hold broccoli heads together at the supermarket) in my WJ. Before you put a strap on the hooks, just take one of the rubber bands and put it higher up on the hook and then when you put the strap on, just pull the rubber band over the strap enough to hold it on. This certainly won't completely stop it from falling off in all cases, but it has often been just enough for mine not to fall off after letting go of it.
If you have a larger rubber band, you can actually pull it out more and twist it and then put it on the hook under the strap as well, tying the strap down to the hook. (If that makes any sense)
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #15 of 15 Old 12-13-2013, 06:07 PM
fast540
Originally Posted by mycreativename
Not to talk down the shackles at all (trust me, I've thought about getting them time and time again cause I like them so much, hah), but I have a simple solution to your straps falling off the hooks issue. I was getting similarly frustrated and actually ripped an eye end of a strap because it halfway-fell off the hook and the hook went right through it. I always have a couple of those produce rubber bands (the ones that hold broccoli heads together at the supermarket) in my WJ. Before you put a strap on the hooks, just take one of the rubber bands and put it higher up on the hook and then when you put the strap on, just pull the rubber band over the strap enough to hold it on. This certainly won't completely stop it from falling off in all cases, but it has often been just enough for mine not to fall off after letting go of it. If you have a larger rubber band, you can actually pull it out more and twist it and then put it on the hook under the strap as well, tying the strap down to the hook. (If that makes any sense)
thats a great idea I've been used vinyl tape to do the same thing
fast540 is offline
