Recirc door repair - JeepForum.com
post #1 of 3 Old 01-11-2014, 11:04 AM Thread Starter
jeffrey1
2003 WJ
Recirc door repair
Has any one used one of the kits where you do not have to remove the dash i only have 1 code 52 all my vents work and all my setting work. Blemdorstore has one to repair the Recirc. And so does Heatertreater Is one better then the other. Do you guys recommend doing the blem doors also or wait for them to break
jeffrey1 is offline
post #2 of 3 Old 01-11-2014, 11:29 AM
greenwj
For the recirc door the "fix" is just to wire it open or closed. IMO, a coat hanger or long bolt is just as good. You basically just wire it to the plastic grate.
I put mine in the closed position because the AC is marginal anyway. Unfortunately that makes the defroster not work as well in the winter. I'm probably going to tear the dash out this summer and fix it correctly.
greenwj is offline
post #3 of 3 Old 01-11-2014, 11:58 AM Thread Starter
jeffrey1
2003 WJ
If you want the AC to work at its best you want it to be open ? And in the winter you want it to be closed ? Does any one have pictures
jeffrey1 is offline
