Recirc door problems - JeepForum.com
post #1 of 6 Old 12-06-2011, 07:04 AM Thread Starter
dave01
ive just replaced the two blend doors using the cut behind the glove box method and they work fine but im getting fault code 52 and have noticed that the recirc door above blower motor has a broken hinge like the blend doors.Is there a fix for this.
dave01 is offline
post #2 of 6 Old 12-06-2011, 09:05 AM
MadderThanMax
Wj
Nice one Dave, ya beat me to that one as I have exactly the same.
Anyone??
MadderThanMax is offline
post #3 of 6 Old 12-06-2011, 11:22 AM
MadderThanMax
On thinking about it ... how often do we use the recirc function over here in Blighty, I can't think of the last time I used one so my question is this ..
Does it need to be fixed seeing as it has little use, or woth the self diagnostics eventually break the door??
post #4 of 6 Old 12-06-2011, 12:33 PM
alfaitalia
Since I never used mine I just cable tied the broken door to the grille you can see when you remove the blower (under glovebox). Did it the same time I did the blend doors. This means air is always taken from outside so no recirc...fine in our climate. Real repair is dash out job....not worth it IMO.
Lots of thread about recirc door on here.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 6 Old 12-20-2011, 03:47 PM
runverferth
I have the exact same thing, code 52. I am trying to remove the blower motor but there is a huge wire harness in the way. Real thick and I can hardly move it. Is there a trick to removing the blower motor? How do you remove it?
runverferth is offline
post #6 of 6 Old 12-20-2011, 04:18 PM
thisguyhasadd2
Thats weird somebody already had an answer to these in a thread when i SEARCHED " wj recirc door access"
http://www.jeepforum.com/forum/f310/...x-pics-347814/
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
Recirc Door code 14, new door...new actuator... no worky... BradMB2004 WJ Grand Cherokee Forum 0 12-05-2011 10:42 PM
recirc door issues bigV WJ Grand Cherokee Forum 2 02-01-2011 04:05 PM
HVAC Issues: Blower Motor Wiring Harness/Connector, Blend Door, Recirc Door Problems mweb WJ Grand Cherokee Forum 2 01-30-2011 01:16 PM
recirc door? Scibbyz99WJ WJ Grand Cherokee Forum 11 01-28-2011 12:37 PM
What % of WJ's have Recirc Door Problems? leadsled jeep WJ Grand Cherokee Forum 10 12-09-2010 04:32 PM
