Rebuild or replace 2003 Jeep Overland? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Rebuild or replace 2003 Jeep Overland?
Dan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Yukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 07-25-2014, 11:23 AM   #1
aaron1956
I have a 2003 Jeep Overland loaded, HO engine, tow package etc.150,000 miles. It has new exhaust, tires, battery. Body and interior in great shape. No tranny problems. Radiator sprang a leak and I burnt the motor up.
Several quotes on rebuilt motor install around $6000 with warranty.
I see my options as:
1. Pay 6G and get my Jeep back with rebuilt warranted motor.
2. Try to find comparable vehicle for 6G and scrap my Jeep.
I don't have a place to part out old Jeep so thats not an option.
I don't have a place or time to rebuild my self.
I am leaning toward option 1. Would like to hear some opinions.
aaron1956 is offline   Reply With Quote
Unread 07-25-2014, 11:38 AM   #2
Cleaner13
If you want to go with something simliar to option 1, I would just put a used engine in. It should cost 1/2 of what a rebuild would be..
The rebuild warranty is only going to be on the work of the engine, if it overheats again they will not warranty stuff like that...
If you go option 2, you could probably get a ton of money by parting out the vehicle as it has a lot of desirable parts that can be swapped in the limiteds and standard laredos...
2001 WJ Limited NV247 4.7
2008 KK Limited MP1522 3.7
Cleaner13 is offline   Reply With Quote
Unread 07-25-2014, 03:38 PM   #3
Fellows45
Get a long block for 2.2k(brand new) and install it yourself. You can get an engine hoist and add all new pumps and seals etc for around 3k and that includes engine warranty. Plus you'll learn a lot a save a lot of money. That's what I would do.
Or get a used engine for 500 with around 70k miles and put that in and save 2500. But hey you get peace of mind and an all new vehicle for the extra 2.5k
2002 Jeep WJ, 4.7, EBC Stage 4 brakes, Bilstein shocks (Still In progress)
1989 Wrangler YJ 2.5, 2 inch body lift, 33 inch tires
Fellows45 is offline   Reply With Quote
Unread 07-26-2014, 08:31 AM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Can you find a used 4.7 for less than $1,200-1,500?
Last time I checked, high mileage 4.7 engines were going for around $1,500.
And once you get to that price point, I wouldn't waste my time on a used motor.
Wheelin98TJ is offline   Reply With Quote
Unread 07-26-2014, 09:25 AM   #5
dadamets
Originally Posted by Wheelin98TJ
Can you find a used 4.7 for less than $1,200-1,500? Last time I checked, high mileage 4.7 engines were going for around $1,500. And once you get to that price point, I wouldn't waste my time on a used motor.
These prices are for the 4.7LO not the 4.7HO that the OP has. The 4.7HO will be more, if you can find a good one used...
dadamets is offline   Reply With Quote
Unread 07-26-2014, 09:47 AM   #6
Wheelin98TJ
JEEP FREAK
Correct, thanks for clarifying that for me.
I was seeing standard output 4.7s going for $1,200-1,500. This was a couple years ago.
I didn't see any for under $1,000.
A used, affordable 4.7 HO could be a very tough find.
Unread 07-26-2014, 10:06 AM   #7
aaron1956
Thanks for all of your input. I sure hate to spend that kind of money but I still think my best bet is a rebuilt motor with a warranty. The HO motor is plenty for pulling my bass boat or utility trailer. I just don't think I will find something in the $6000 price range that would serve my needs like the Jeep will when I get it back.
Unread 07-26-2014, 09:34 PM   #8
madZJ
I say rebuild, bore it .30 over and address the valve issue with some cnc ported heads.
madZJ is offline   Reply With Quote
Unread 07-27-2014, 08:55 AM   #9
Cleaner13
[QUOTE=madZJ;24514538]I say rebuild, bore it .30 over and address the valve issue with some cnc ported heads.[/QUOTE
If its going to be rebuilt I whole heartly agree with this above, at the very least address the valves...
OP have you considered just buying another overland for the 6000? Part the other out?
I know by me (dealer wise) there are atleast 8 overlands for 6000 or less...
Or you can even drop to an 02-04 Limited with the HO engine...
Or spend even less and just get a limited(probably under 3000) and swap the overland stuff to it...
I would really hate to see you spend 6000 on a repair of an 11 year old vehicle...
By the way, why did you need a new exhaust? (I just read that part on your original post) The factory system is stainless...
Unread 07-27-2014, 10:21 AM   #10
grand1232
I would sell you my overland for 2500...runs perfect just has a bad catalytic converter and rocker rust. Not really a parts car per se as its inspected and used everyday...but could fix your car.
grand1232 is offline   Reply With Quote
Unread 07-29-2014, 07:12 AM   #11
aaron1956
What valve issue are you referring to?
Unread 07-30-2014, 07:46 AM   #12
aaron1956
Thanks for all your replies. Like I said in my original post, I don't have a place to change out motor or part out a vehicle. ( I live in a Senior citizen mobile home park and they don't allow major work, which is a good thing!)
I shopped around and decided it will be very difficult to find a vehicle for $6000 that will do what my Jeep will do. (Pull my boat, 4WD, 3 yr warranty on engine, new radiator and water pump) I might if I shopped long enough but I don't have time. (Or another vehicle right now). I decided on rebuilt engine install. Thanks again for all your input!
Unread 07-30-2014, 07:54 AM   #13
WXman
Be careful who you buy the "new" rebuilt motor from. Previous owner of my WJ spend over $2,000 for a "rebuilt" motor and ended up getting two bad ones from the manufacturer and they refused to warranty engine #2. He got burned really bad. Think he bought it through Advance Auto Parts, but it wasn't their fault. It was the fault of ATK...the company who ship them out as junk.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline   Reply With Quote
Unread Yesterday, 08:13 AM   #14
kc2mrg
kc2mrg's Avatar
I was gonna say how much do you want to sell the shell for? Id be interested in it if you decide not to fix it .. depending on where you are that is
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 (~31") General Grabber AT2's
Superchips 3875 Flashpaq
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline   Reply With Quote
Unread Today, 05:02 PM   #15
aaron1956
I dove it home today!
