Rear Wiper issue - JeepForum.com
post #1 of 10 Old 08-18-2014, 09:02 AM Thread Starter
jamesrw30
Rear Wiper issue
Suddenly my rear wiper will not pick up from the ramp it sits in. If I turn on the switch I hear and see the arm try to pick up but it will not go anywhere. I assume the motor is good. I hear it trying to work. Would gears be tripped out or just something in the binding up the arm? I am kind of at a loss where to go on this issue so any help would be very much appreciated.
jamesrw30 is offline
post #2 of 10 Old 08-18-2014, 09:52 AM
jeepfvr
The nut that holds it from the back side may be allowing it to twist the motor itself inside the hatch. Take off the rear interior panel on the hatch turn on the rear wiper and see what it's doing.
jeepfvr is offline
post #3 of 10 Old 08-18-2014, 10:27 AM
Double E
Double E's Avatar
It sounds like the wiper blade is binding at the base of the glass.
Flip out the wiper arm as if you were going to replace the wiper blade and turn it on. That will tell you if it is capable of sweeping.
The arm may just need to be bent a little when parked to get he blade to go past the base of the glass.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 10 Old 08-18-2014, 11:04 AM Thread Starter
jamesrw30
I have done both of these and gotten the same results. When I lift it as to change the blade it still doesn't sweep. Everything on the motor seems to be secure also. First thing I did was pull the panel off the inside of the door and everything seems to be as it should be.
post #5 of 10 Old 08-18-2014, 11:57 AM
SirSilvia
take the wiper arm off and turn it on, then look to see if the motor shaft moves at all. I never use mine and it was crusted up from calcium/salt deposits and a little rust
2002 Jeep Grand Cherokee Limited V8
SirSilvia is offline
post #6 of 10 Old 08-18-2014, 12:17 PM Thread Starter
jamesrw30
Makes good sense. I have never pulled a wiper arm off an remember seeing something on wjjeeps.com that it requires a tool to do so. I think it said a battery terminal puller. Is this the case or can it be done without?
post #7 of 10 Old 08-18-2014, 12:54 PM
SirSilvia
I used the claw side of a hammer and a piece of wood. to prevent dents.
post #8 of 10 Old 08-18-2014, 12:55 PM
Double E
Double E's Avatar
I did without. Remove the nut and tap the edges of the wiper base first though.
On the windshield wipers I was able to get a claw hammer under it and pry up with some layers of cardboard under the fulcrum point of the hammer to protect. Couple of taps, pull in different spot, repeat.
Rock the arm around a bit too. A little PB blaster sprayed in there will probably help.
Battery term puller is smarter though.
Re-assemble with anti-sieze on the shaft.
Double E is offline
post #9 of 10 Old 08-18-2014, 01:41 PM
DC99
2017 WK
In my case and others I read have the similar issue that the shaft get frozen in the housing from the elements. There is a nice right up but cant remember where I read it about removing the hatch cover, remove the motor assy and disassemble the motor to free it up, lube and reassemble. Maybe someone else can chime in on this issue. I did this with good results, never had a issue since.
DC99 is offline
post #10 of 10 Old 08-18-2014, 01:48 PM Thread Starter
jamesrw30
Thank you for the info everyone. I will look into this. Hopefully I can figure something out. It is at the body shop at the moment getting hail damage repaired so hopefully I can get on this once I get it back.
