Rear view camera HELP !!!! - JeepForum.com
post #1 of 6 Old 01-23-2014, 03:02 PM Thread Starter
Tony562
Wj Rear view camera HELP !!!!
Hello I have been trying to install my rear view camera on my 2004 Jeep Grand Cherokee Laredo and it has been a fail all I get is a black screen when switching to the reverse gear but when selecting manually it shows the image on the screen any help would be appreciated. Here's how I have it installed:
1. Yellow RCA connected to back of pioneer avh p1400 DVD
2. Red power wire from camera connected to head unit power 12V
3. Ground connected to a good ground source
4. Purple double din wire connected to purple reverse tail light wire purple and white I believe (not sure if this is the wire for the back up taillight bulb?)
5. Camera source off as pioneer suggested
6. Polarity on battery
Any help would be appreciated!
Tony562 is offline
post #2 of 6 Old 01-23-2014, 10:37 PM
mountaintracker
I've installed a few backup cameras, so let me see if I can help you. I am not however familiar with the pioneer headunit, so that may issues. Lets first start with a better understanding of your symptoms versus goals.
Are you trying to have it so that you have the display show your backup camera source when you go into reverse gear?
Typically, the way that works is by having the camera power or camera power trigger line wired into your reverse light, so that your camera is only on when in reverse, and your not drawing current all the time on it. Some actually put a threeway switch in there for reverse or manual activation.
I'm not quite sure what you mean by purple double din, if your trying to figure out which the reverse wire is, I would pull the back lens and check the color or the wires on your reverse bulb. It is two screws to swing it out. I can't remember exactly which color it is, etc.
You also mention that when you select manual, I presume on the pioneer unit, you can get the image. Are you talking the camera image?
If your camera is already working, then its up to understanding how to set up the pioneer unit so that either is always on the source channel for your camera or if it switches to that active channel, some don't. Typically there is a default channel or way to set up through the unit to switch to an active source. Then it is just a matter of wiring your camera trigger, or power depending on the camera, to your rear lights.
If you can answer those two questions and maybe describe to me the way you have it wired, and more importantly, what wires you have and what they do, that would really help. Also just what your intent is as far as overall goal. There are just a few too many configurations to know how best to answer help given what you've said. But there are only a few ways to do it.
WJ 4.7L*245/75R16*Mopar Front/Fuel Skids*KOR T/C Skids*JCR Sliders*Flowmaster 50*Airraid MIT*OME HD*Bilstein 5100s*JKS Trackbar*ARB Bumper*SB XRC 10*Zone links*Almost as much electronics as Batman..
mountaintracker is offline
post #3 of 6 Old 01-23-2014, 10:57 PM
DavisI
I'd make sure you have the correct reverse light wire, that seems like its the issue here.
DavisI is offline
post #4 of 6 Old 01-23-2014, 11:01 PM
mountaintracker
Ok I just read through the head unit manual so disregard some of my questions, I understand your list a bit better now. So if I understand right, you've got the camera black grounded and red to the head unit. I presume that is the only two wires? On the head unit you have the polarity set at battery which sounds right based on the manual. The camera RCA to the "RC in" on the back of the head unit. It sounds like there are multiple videos in, so that is one to double check.
The question remains over whether your camera is working or not. If it is, and your just not getting it to switch over on reverse, then I would say its something to do with the reverse trigger wire. Two things I would do there. The first is ensuring you have tapped into the reverse lights, by tracing as I suggested. I have a voltmeter with little piercing prongs so I clamp one to a good ground then test probe the wires till I get the one that lights up to 12 volts when I shift into reverse. Purple/white rings a bell, but its been a while. You just need to make sure your tapping a volt line and not ground return, as the head unit is expecting voltage to hit that wire.
post #5 of 6 Old 01-24-2014, 11:18 AM Thread Starter
Tony562
Alright thank you very much I will check that as soon as I get home.
Tony562 is offline
post #6 of 6 Old 01-28-2014, 07:57 PM
berndog67
2003 WJ
let us know how u make out and what the correct wiring is, cuz im thinking of doing a similar setup for a reverse camera to help while wheeling!
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
