rear upper control arm/ball joint - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > rear upper control arm/ball joint
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 05-09-2010, 03:25 PM   #1
almostfinished
Hey guys, I've got a knock in the rear over small bumps, sounds like a bad strut sound. I've since replaced the shocks along with the sleeves (for no upper shock mount play), along with the sway bar links and mount bushings. Sound is still there so my next step is to pull the upper control arm out and replace the ball joint. My question is, is there any harm in removing the upper control arm and still driving the jeep? Cautiously of course. To me it seems as if the upper control arm is over kill. I have worked on many vehicles with just control arm/springs attaching the rear to the vehicle. Thanks for the info!
nick
2002 Grand Cherokee Limited. Stock for now
almostfinished is offline   Reply With Quote
Unread 05-09-2010, 08:26 PM   #2
WiCkeDuDe
WiCkeDuDe's Avatar
If your talking about the rear A coming out and driving the answer is ABSOLUTELY NOT! You CANNOT drive without it. There is nothing to center the axle from side to side without the a arm on a WJ.
Did I happen to say no???
WiCkeDuDe is offline   Reply With Quote
Unread 05-09-2010, 08:33 PM   #3
StrokedWJ
x2, my answer was very similar on JU. First thought was: "Yeah dude, that upper control arm, WTF's that for? Totally unnecessary...get that **** outta here." Make sure you have a friend with a camera filming when you go for the test drive.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Unread 05-10-2010, 10:37 AM   #4
nick62087
I doubt it'd even move. Actually, just putting the weight of the vehicle on the ground might be funny.
Under any acceleration, I'd imainge the rear would roll, and promptly break something. Might be interesting to watch though.
nick62087 is offline   Reply With Quote
Unread 05-10-2010, 03:33 PM   #5
almostfinished
I kind of figured that much with the centering remark. Been working on vehicles for 9 yrs (ase master tech for 7 of the 9) I have seen plenty of link set ups. This is the oddest set up to be honest. I'll have to get under there and pull out the upper control arm and replace the ball joint. Anyone know of a company or where I can get a loaded upper control arm (with ball joint installed)? I'll be replacing the front upper and lowers along with the rear lowers also. Thanks for the info fellas.
Nick
Unread 05-10-2010, 05:03 PM   #6
WiCkeDuDe
WiCkeDuDe's Avatar
It just bolts into the axle housing using 3 bolts. The control arm takes the tapered ball joint end. Take another look at it. Or several.
Unread 05-10-2010, 05:35 PM   #7
almostfinished
I'm going to replace all the control arms with new ones including bushings. Jeeps got 110k on it and they are pretty dry rotted along with a bit of a wobble after hitting some bumps at highway speed. A friend of mine broke my press to get the ball joint out so i figured I would just replace the upper control arm/bushings and ball joint all in one.
Unread 05-10-2010, 08:07 PM   #8
nick62087
I've heard of people buying the a-arm with the ball joint and bushings already installed, can't remember where though.
Planning on going taller with the lift? IRO is having a group buy - you could always consider getting all adjustable aftermarket arms.
Unread 05-10-2010, 08:37 PM   #9
patrick983
dealership is the only place to get the actual arm i believe. if you want just the bushing in its mount (so you dont have to press it in), rockauto.com sells one for ~20 bucks or so.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn [B]SOLD and missed very badly[/B]
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline   Reply With Quote
Unread 05-10-2010, 09:38 PM   #10
the88thpianoman
the88thpianoman's Avatar
2003 WJ
Someone on here (no memory of who) mentioned getting the arm with ball joint already installed on ebay a while back. Don't know how it worked out for them, but might be worth checking around.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 05-12-2010, 08:53 AM   #11
almostfinished
I had thought about lifting the jeep at one point or another but its more of a 2nd vehicle (spare) now. I'm really just looking to replace the arms and bushings now. I cannot stand any rattles/knocks, I'm a clean freak too so any little thing bugs me lol. I'll keep an eye out on ebay and other websites. thanks for the help fellas
Nick
Unread 02-07-2012, 01:20 PM   #12
ppiya123
i have a little knock on the rear. i thought it was the sway/stabilizer bar and bushings. i replaced them all along with all four shock absorbers. i still have the knock. Could it be the upper control arm ball joint? if so, how hard is it to replace? my jeep is pretty badly rusted underneath. here's a picture of the upper side of the ball joint. can i replace just the ball joint plate without removing the control arm?
ppiya123 is offline   Reply With Quote
Unread 02-07-2012, 01:29 PM   #13
allenrotstein
Yes, you can replace the ball joint without removing the c-arm, it will be a lot harder without the proper tools tho.
Clean up all that rust with a wire brush first... The more prep work you do to remove all that rust, the faster you can set the ball joint free.
A mix of "Acetone + ATF fluid" (1 to 1 mix) will work 100x better than any PB Blaster
Grand Cherokee 99-04 WJ Service Manual: http://www.mediafire.com/?kl96h9vmk9979fp
Grand Cherokee 05-08 WK Service Manual: http://www.mediafire.com/?4q51ake1023nlb6
allenrotstein is offline   Reply With Quote
Unread 02-07-2012, 01:50 PM   #14
ppiya123
can i ask what kind of tools i need? i'm planning on replacing the ball joint plate altogether. can i lift the car, after removing the ball joint bolt, to set it free from the c-arm?
Unread 02-07-2012, 01:53 PM   #15
ppiya123
and thanks for the tip about acetone+ATF. i read about it and tried AeroKroil which is pretty good compared to most penetrating oil in the market but kinda expensive. i'm going to keep a spay bottle with ATF and acetone mix.
