rear shocks 2004 jeep grand cherokee - JeepForum.com
post #1 of 15 Old 03-28-2012, 03:52 PM Thread Starter
ecwv1
Hi all,
I replaced my rear shocks 04 grand laredo. Seems to have helped with the ride but now there is a clunking noise when hitting a bump or speed bump. all other driving seems to be fine. Made sure bolts are tight, not sure where to go next.
ecwv1 is offline
post #2 of 15 Old 03-28-2012, 04:22 PM
ChrisHager
Administrator
ChrisHager's Avatar
I would check to make sure the sway bar end links are tight but I'm willing to bet the sleeves in the new shocks are a little bigger than the bolt, causing them to clunk...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #3 of 15 Old 03-28-2012, 07:02 PM
chrism1367
2003 WJ
I just did the same thing, replaced rear shocks, and what do ya know i have the exact same problem. It has to be something just barely not fitting right.
chrism1367 is offline
post #4 of 15 Old 03-28-2012, 07:42 PM Thread Starter
ecwv1
thanks for the response. checked swaybar and its tight.
I noticed that the bolt slid in pretty easy so that may be an idea.
I didnt think it make that much of a differene. So now the stupid is can i buy a spacer or a bolt with a larger diameter shaft but same threads? or is there another fix?
ecwv1 is offline
post #5 of 15 Old 03-29-2012, 04:58 AM
vwbuge
The upper rear shock mount sleeves are too short. It is best to take stock ones out of old shocks and reuse. If you still have them, that is the best option. You can go the inexpensive route and place large washers on either side of the sleeves and reinsert the bolt and tighten.
2002 Grand Cherokee Limited
4.7 HO
2" BB Rusty's shocks
245/70-17
vwbuge is offline
post #6 of 15 Old 03-29-2012, 09:40 AM
FrankU
Has anyone tried this product ? With results ?
http://www.kevinsoffroad.com/cart/in...roducts_id=153
04 WJ 4.0, OME Kolak 3" lift, Addco's F&R ,18" JK Sahara's
FrankU is offline
post #7 of 15 Old 03-29-2012, 10:17 AM
Redrum_1
Pull out one of the bolts and look at it closely. You will find there is a step like a shoulder on it. Take it to the hardware store and get grade 8 metric bolts the same size and put those in. It should fix the problem. I went through the whole thing too replacing everything and not helping the problem till I looked at the shock mounting bolts.
I attached a pic of the bolt, Its not real clear but you can see where its worn, or made that way. I'm not sure which is the case.
Good Luck!!
2013 Dodge Ram 1500 Express Quad Cab. 5.7L Hemi 6 speed automatic 3:55 gears LSD with 20 inch rubber
2000 Jeep Grand Cherokee Limited 4.0L
2003 Nissan 350Z Enthusiast Model 6 speed manual
2002 Audi A6 Avant Quattro 3.0L Auto
Redrum_1 is offline
post #8 of 15 Old 03-29-2012, 11:40 AM
rockyrivermark
my 2002 GC was doing the same thing. I put new shocks all around. you have to crank them down in the back bigtime. Use and implact and it will squeeze the steel bracket tight to the shock.
I was a bit concerned about breaking the bolt but it drew it in nicely and tight to the shock.
no more clunks.
rockyrivermark is offline
post #9 of 15 Old 03-29-2012, 12:21 PM Thread Starter
ecwv1
thanks for all the posts. i have my brackets pretty tight so im thinking its the up and down on the bolt and not side to side. I will get different bolts in a couple of days and let you know what i find.
ecwv1 is offline
post #10 of 15 Old 03-29-2012, 12:31 PM
chrism1367
2003 WJ
Cool post back when youre done i think i will be doing the exact same thing. Just need to find out how to get to the store with the bolt, since the jeep is my only ride lol
post #11 of 15 Old 03-29-2012, 01:21 PM
DustinWJ
just leave one of the shocks out along with that one bolt it will be fine tell you get back
DustinWJ is offline
post #12 of 15 Old 03-29-2012, 04:08 PM
Double E
Double E's Avatar
If this doesn't solve the issue, I think the upper A-arm is in question, ...right gents?
I ask because after replacing shocks, I still kave some clunks over big bumps and big road imperfections.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #13 of 15 Old 03-31-2012, 02:18 PM Thread Starter
ecwv1
Thanks for all the feedback. I checked my bolts and they seemed ok. Got my 18v impact out and was able to tighten them down enough with it to correct this issue. thanks again for all the help.
ecwv1 is offline
post #14 of 15 Old 08-23-2012, 02:23 PM
SilverOne23
I've got a 2004 laredo and got the same clunking after replacing the factory shocks with MonroeSensa-Trac Light Truck Shock Absorber from Advance Auto. bought them online and used a $50 promo code I found online. Picked them up at the store an hour later-great deal 4 shocks for $135 and these are a step up from OEM I believe.....
Anyway, after reading here about clunks, and not being able to find washers that fit in my junk box, I just tightened the top bolt down really hard-really hard-It's a huge bolt and I don't think it will snap very easily. Took it around the block and the clunking is gone.
By the way it took me 1 1/2 hours to replace all four and didn't have to even use a jack-these shocks came with a plactic band around the upper and lower keeping them at the exact length for the back. the front I had to cut the band and muscle the shock smaller into place-not that big of a deal for an old man of 52.
Good luck everyone.
SilverOne23 is offline
post #15 of 15 Old 08-19-2013, 12:09 AM
namtrah
namtrah's Avatar
Wj Not so lucky
After searhing the forum...finding out about the clunk, bought new bolts for rear uppers and guess what? The stout bolt on top snapped on the way out! Yea! So tonight we spent hours trying to remove it, and no such luck. Now I have the threaded internal bushing with remaining metal from drilled out bolt. I have no access from other side. So not I drilled holes above the unibody rail and took a peek. The threaded bushing appears to be the entire width of the rail. I'm guessing it is either welded or pressed into position. I may be opening up the hole bigger in cargo area gain access and figure out how to use a bolt, washer, nut combo. This will make it a ***** for shock replacement in future, but cannot find another solution.
04 WJ Laredo-4.0L-NP242-KN Fipk-Borla Exh w/Hi-Flo Cat-6" Lift
namtrah is offline
2004 Jeep Grand Cherokee won't start :( jennybugz WJ Grand Cherokee Forum 2 10-16-2012 09:33 PM
2004 Jeep Grand Cherokee shocks? stanj WJ Grand Cherokee Forum 8 07-13-2012 01:26 PM
2004 jeep grand cherokee wj lift help 04jeepin WJ Grand Cherokee Forum 2 03-28-2012 05:45 AM
2004 Jeep Grand Cherokee (WJ) Tire Question paulcicero WJ Grand Cherokee Forum 8 06-30-2010 06:42 PM
Headlights on the 2004 Jeep Grand Cherokee boyandhisjeep WJ Grand Cherokee Forum 1 10-21-2003 02:38 PM
