Rear shock thump AFTER replacement. - JeepForum.com
post #1 of 3 Old 07-21-2017, 06:33 PM Thread Starter
Dlav1997
Unhappy Rear shock thump AFTER replacement.
So I've slowly been replacing the suspension parts on the rear end of my 01 Laredo.
I got to the shocks the other day and replaced them with Monroe shocks. (https://www.rockauto.com/en/moreinfo...381441&jsn=388)
The whole Rig rides a hell of a lot smoother and was well worth the parts change, however I now have a thumping noise that seems to be coming from the rear passenger shock area. It's whenever I drive over road imperfections such as bumps and potholes. The driver side rear does not make the noise. That being said all of the bolts are nice and snug, but when I went to see if the shock in question had any movement while tugging and pushing on it, it did slightly move making a clicking sound. It is completely solid when tugging side to side but when pushing on it back and fourth towards the vehicle and away from the vehicle, there is movement. The Driver side rear does not have this movement. I'm guessing that my noise has something to do with that slight play but I am unsure as to how to fix it. Should I just try to tighten the lower bolt some more? Has anyone else ran into this issue?
Any feedback is appreciated, thank you.
Dlav1997 is offline
post #2 of 3 Old 07-21-2017, 07:24 PM
JeepinMass
JeepinMass's Avatar
The WJ has an odd width for shock mount You can get the Kevin's Off-Road kit https://kevinsoffroad.com/product/wj...our/#gsc.tab=0 or you can use a fender washer. That could very well be the issue.
--Ben--
74CJ5 and 04 WJ
JeepinMass is offline
post #3 of 3 Old 07-21-2017, 07:59 PM
blueseasons1
I have these on my WJ and they work fine.. Tighten it up and see what happens. Swap it with the divers side and if it travels ask to exchange it for another one.
blueseasons1 is offline
