Rear shock mounting orientation - JeepForum.com
post #1 of 3 Old 06-10-2013, 08:30 PM Thread Starter
RIPNBST
Is there a preferred way to install rear shocks on the WJ? I've installed mine with the shock body upwards. I've seen them installed both ways in images posted on here.
I was wondering if there was a preferred orientation among those with more experience than I due to whatever reasoning. IE, body down for added protection from rocks bashing shaft, shaft up for added tire clearance, etc.
RIPNBST is offline
post #2 of 3 Old 06-10-2013, 08:42 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Makes no difference whatsoever unless the specific shock you are using requires a particular orientation.
~James
ezflip is offline
post #3 of 3 Old 06-12-2013, 08:00 PM
berndog67
2003 WJ
fwiw, i mount my rear shocks body side down, allows another inch or so of up travel without rubbing anything, course im at 4" on 32's with the stock overland wheels, wont make a difference when i get wheels with 4" backspacing like most everyone else on here
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
