Rear power supply troubles - JeepForum.com
post #1 of 6 Old 07-16-2013, 10:38 PM Thread Starter
Msutorka
My 2000 wj was the Laredo stock basic as it gets version I want the rear power supply got the socket at a pick and pay but I opened up my back where it should go and there's no wire to connect it up to what do I have to do to make it work how do the factory ones hook up and also the front power supply if I can score one from the jy how does that hook up what do I need
Msutorka is offline
post #2 of 6 Old 07-16-2013, 11:40 PM
99WJ539918
Grammar fail, big time. Power it from the one up front.
Build Thread
99WJ539918 is offline
post #3 of 6 Old 07-17-2013, 08:47 AM
bugaboots
Here is a link to wjjeeps it has a nice walk through on how to do it.
http://www.wjjeeps.com/power_outlet.htm
1995 Cherokee 4.0 Stock(for now)
2002 Grand Cherokee Sport, OME HD lift, Bilstien 5100's, 63mm Bored t-body, IRO 2.5 exaust, 245/75/16 Revo2, Front tow hooks, 4.6L long rod stroker, Factory Jeep brush gaurd
bugaboots is offline
post #4 of 6 Old 07-17-2013, 12:29 PM Thread Starter
Msutorka
Got the pin connector where should I run my wires to? Does it run straight to the battery from the factor or does go through a computer, fuses,relay??
Msutorka is offline
post #5 of 6 Old 07-17-2013, 03:20 PM
rdkendrick
2003 WJ
From the walk through that BUGABOOTS posted, you plug the outlet connector into the connector here:
http://www.wjjeeps.com/cargo_12v_8.jpg
If you followed the instructions in that write-up, you should have found that connector tucked in behind the trim panel.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #6 of 6 Old 07-18-2013, 01:03 PM Thread Starter
Msutorka
I already read the jeepwj site and opened the back but my jeep came with out the plug to hook it up. I got a plug from the junk yard and ran my own wires to a rocker switch.
Msutorka is offline
