"Rear Lower Track Bar"- Mechanic?! - JeepForum.com
post #1 of 14 Old 05-22-2013, 01:18 PM Thread Starter
Genericusername
EDIT : Title should read Track Arm not bar.
Hey guys, took my 02 WJ into the mechanic because my front end went wobbly after going over a railroad crossing. I stopped the vehicle and started driving and noticed no problem but only when going over a railroad. The mechanic said I need new upper CA bushing and a new rear lower track arm. He said that's what the dealers call it. I called a dealer and the parts guy said they don't know hat that is. So I have never heard of that have you guys? Does he mean lower CA and not realize it?
1997 ZJ 5.2L V8 256,000 miles "Fart"
Originally Posted by m_amilli View Post
by the thing that spins when you drive underneath
Genericusername is offline
post #2 of 14 Old 05-22-2013, 01:19 PM
adavis39
ZJ's use a rear trac bar. the WJ does not. He sounds confused
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #3 of 14 Old 05-23-2013, 12:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Track arm, trailing arm, control arm, all the same things.
ratmonkey is offline
post #4 of 14 Old 05-23-2013, 04:36 PM Thread Starter
Genericusername
Hey thanks, he used those terms interchangeably when he left me a voicemail and when I spoke with him on the phone. I didn't know it by any other name then control arm. So the part in question is part 13 on this diagram. Which is what he was talking about.
So now my question is they are charging $358 to replace it. $120 for the bushing and center arm bushing. Is this something I can do with a buddy with tools borrowed from Advanced Auto over a weekend or would it be worth it to just have them do it given the work involved? Thanks guys as always.
post #5 of 14 Old 05-23-2013, 05:03 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
ah, that's the upper a arm. it's not too hard to do in your driveway. i'd just buy the whole assembly instead of trying to do bushings and the ball joint though.
post #6 of 14 Old 05-23-2013, 05:29 PM
doityourselfMM
doityourselfMM's Avatar
AMEN to that. The time and 'grief' saved is worth the money! I've done three, and I'd rather be drinking beers...
doityourselfMM is offline
post #7 of 14 Old 05-23-2013, 10:29 PM Thread Starter
Genericusername
Not to sound ignorant but what do you mean but whole assembly?
post #8 of 14 Old 05-23-2013, 11:48 PM
85IrocZ-28
An entire new metal A-arm, you can get it with new body side bushings and a new ball joint for the rear axle mount.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #9 of 14 Old 05-24-2013, 07:23 AM
bugaboots
If your interisted i have a spare a-arm laying around i could throw some new parts into this weekend and ship out to you monday. Be cheeper than new and almost as good.
1995 Cherokee 4.0 Stock(for now)
2002 Grand Cherokee Sport, OME HD lift, Bilstien 5100's, 63mm Bored t-body, IRO 2.5 exaust, 245/75/16 Revo2, Front tow hooks, 4.6L long rod stroker, Factory Jeep brush gaurd
bugaboots is offline
post #10 of 14 Old 05-24-2013, 11:17 AM Thread Starter
Genericusername
Any good sites for the assembly that you would recommend?
post #11 of 14 Old 06-20-2013, 04:09 PM Thread Starter
Genericusername
Hey I figured no point in starting a new thread if I can get some replies this way. I have the new ball joint and A arm up in the jeep. However the drivers side bushing won't line up with the hole to put the bolt through. I have the frame jacked up so the rear end hangs. I also lowered it to the ground and still can't get the holes to line up. Any thoughts? It's a crown replacement arm part # 52088422AB.
post #12 of 14 Old 06-20-2013, 06:35 PM
tim0
Big pry bar or pipe and push or pull the rear end around to line it up as needed.
tim0 is offline
post #13 of 14 Old 06-21-2013, 09:46 AM
85IrocZ-28
Please clarify...you can get the drivers side bushing in, but the spacing isn't correct and the passenger side doesn't line up? If so, your vehicle may have been in a serious enough accident that the unibody is bend. Either that, or the crown replacement isn't built correctly.
post #14 of 14 Old 06-23-2013, 07:35 PM Thread Starter
Genericusername
This is what concerned me.
However,
I rocked the rear end slightly while a buddy was underneath finessing that bolt in. It's in and with a slightly noticeable less swaying rear.
