-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   "Rear Lower Track Bar"- Mechanic?! (http://www.jeepforum.com/forum/f310/rear-lower-track-bar-mechanic-1526866/)
Genericusername 05-22-2013 01:18 PM
EDIT : Title should read Track Arm not bar.
Hey guys, took my 02 WJ into the mechanic because my front end went wobbly after going over a railroad crossing. I stopped the vehicle and started driving and noticed no problem but only when going over a railroad. The mechanic said I need new upper CA bushing and a new rear lower track arm. He said that's what the dealers call it. I called a dealer and the parts guy said they don't know hat that is. So I have never heard of that have you guys? Does he mean lower CA and not realize it?
adavis39 05-22-2013 01:19 PM
ZJ's use a rear trac bar. the WJ does not. He sounds confused
ratmonkey 05-23-2013 12:10 PM
Track arm, trailing arm, control arm, all the same things.
Genericusername 05-23-2013 04:36 PM
Hey thanks, he used those terms interchangeably when he left me a voicemail and when I spoke with him on the phone. I didn't know it by any other name then control arm. So the part in question is part 13 on this diagram. Which is what he was talking about. http://www.jeep4x4center.com/jeep-su...ion-fixed2.jpg
So now my question is they are charging $358 to replace it. $120 for the bushing and center arm bushing. Is this something I can do with a buddy with tools borrowed from Advanced Auto over a weekend or would it be worth it to just have them do it given the work involved? Thanks guys as always.
ratmonkey 05-23-2013 05:03 PM
ah, that's the upper a arm. it's not too hard to do in your driveway. i'd just buy the whole assembly instead of trying to do bushings and the ball joint though.
doityourselfMM 05-23-2013 05:29 PM
AMEN to that. The time and 'grief' saved is worth the money! I've done three, and I'd rather be drinking beers...
:cheers2:
Genericusername 05-23-2013 10:29 PM
Not to sound ignorant but what do you mean but whole assembly?
85IrocZ-28 05-23-2013 11:48 PM
An entire new metal A-arm, you can get it with new body side bushings and a new ball joint for the rear axle mount.
bugaboots 05-24-2013 07:23 AM
If your interisted i have a spare a-arm laying around i could throw some new parts into this weekend and ship out to you monday. Be cheeper than new and almost as good.
Genericusername 05-24-2013 11:17 AM
Any good sites for the assembly that you would recommend?
Genericusername 06-20-2013 04:09 PM
Hey I figured no point in starting a new thread if I can get some replies this way. I have the new ball joint and A arm up in the jeep. However the drivers side bushing won't line up with the hole to put the bolt through. I have the frame jacked up so the rear end hangs. I also lowered it to the ground and still can't get the holes to line up. Any thoughts? It's a crown replacement arm part # 52088422AB.
tim0 06-20-2013 06:35 PM
Big pry bar or pipe and push or pull the rear end around to line it up as needed.
85IrocZ-28 06-21-2013 09:46 AM
Please clarify...you can get the drivers side bushing in, but the spacing isn't correct and the passenger side doesn't line up? If so, your vehicle may have been in a serious enough accident that the unibody is bend. Either that, or the crown replacement isn't built correctly.
Genericusername 06-23-2013 07:35 PM
This is what concerned me.
However,
I rocked the rear end slightly while a buddy was underneath finessing that bolt in. It's in and with a slightly noticeable less swaying rear.
The time now is 01:00 AM.
