Rear knocking noise - JeepForum.com
post #1 of 9 Old 01-10-2012, 07:47 AM Thread Starter
tommyqit
Wj Rear knocking noise
When I go over a pothole or similar I get a knocking noise at the rear ,The garage (not jeep) tells me the shocks are OK and can't seem to see any problem
When you push the body up and down its OK , its only when the wheel is pushed up it makes the noise which is hard to replicate in a garage , Any ideas what it could be !!!
tommyqit is offline
post #2 of 9 Old 01-10-2012, 08:46 AM
wjjeeplkstevens
Rear ball joint on the upper control arm (A arm). 9 times out of ten knocking in the rear over bumps its this ball joint failing.... Kind of a PITA to replace yourself but with some patience, a 21 mm open end and some leverage it can be done.... And a puller to get it off the a arm. Alot of guys will take the A-arm assembly out (2 more bolts, plus a few small brake/e-brake line retainers) and replace the ball joint on the bench and put it back in...
wjjeeplkstevens is offline
post #3 of 9 Old 01-10-2012, 08:50 AM
dave01
I agree with the above...
dave01 is offline
post #4 of 9 Old 01-10-2012, 09:40 AM Thread Starter
tommyqit
Wj rear knocking noise
That's good news , I'll probably change out the two bushings as well on the upper suspension arm which I thought might have been the problem . Thanks again lads
tommyqit is offline
post #5 of 9 Old 01-10-2012, 09:46 AM
Double E
Double E's Avatar
Can I get a pic of this part (as installed) on the WJ?
I want to see exactly what I need to be looking for....
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #6 of 9 Old 01-10-2012, 08:10 PM
wjjeeplkstevens
You need this.... Oreilly Auto parts sold me a 'rear ball joint' and it was just the ball joint, no mounting plate. You may be able to press it in and out but not worth the time.. I went to car-quest and got one and it came as an 'assembly', same price. Or there is a alot of options online.... Also to replace the other two bushings on the a-arm, those have to be pressed out and new ones pressed in. Kind of a bear to do as they are normally pretty rusted in there... may want to look at ebay for a whole new a-arm with new bushings already in it-generally pretty cost and time effective unless you have a press with the correct dies to do it yourself.....
post #7 of 9 Old 01-10-2012, 10:17 PM
Voltage258
2003 WJ
It could also be your shock mounts if you have upgraded shocks and not the OEM ones. Mine clunks to but it only clunks on the right side so im assuming its the shock mounts. If i pull up on the right side wheel well and rock the car up and down i can hear a very quite pop noise but if i do it on the left side i cannot here anything. So seeing as they are only $20 im going to try those first. Here is the link if you wana get new ones and try those out.
http://www.kevinsoffroad.com/cart/in...roducts_id=153
03 Grand Cherokee, 4inch Zone lift 15inch craiger soft 8's 31 inch duratracs nothing to special. SOLD
82 Grand Wagoneer Limited. Amc 360, Bridgstone MT's
Voltage258 is offline
post #8 of 9 Old 01-11-2012, 03:09 PM
GoreD
top 3 would be sway bar links, shock or shock mount, and upper arm ball joint. Get under there with a pry-bar and see if any of these have any play in them. I just had to fix up the sway bar links on mine as the lower part of the link was rattling over bumps.
GoreD is offline
post #9 of 9 Old 07-26-2012, 04:05 PM
danasince1979
2006 XK Commander
definitely check out that upper rear control arm ball joint. mine jeep was making a pretty solid clunking noise in the rear that for some reason seemed to be worse when i took my foot off the accelerator and let it coast over bumps. this was driving me nuts for the last 6 months. i had all new shocks, springs, isolators when lifted. replaced the upper control arm bushings and rear lower control arms (was easier to replace the whole arms than deal with swapping out the bushings and not that much more really). the sway bar and end link bushings were all fine but i was still getting the clunk. got under it and had a couple people jump on the bumper and could see the ball joint separating. replaced it with one of these and now everything is all good.
danasince1979 is offline
Knocking noise from engine markpin WJ Grand Cherokee Forum 13 01-22-2012 03:56 PM
weird knocking noise dafox WJ Grand Cherokee Forum 13 03-10-2011 08:13 AM
1999 WJ 4.7 Knocking noise xowiickedox WJ Grand Cherokee Forum 1 01-07-2011 07:58 PM
99 WJ 4.7 making a knocking noise/ Video xjdrew WJ Grand Cherokee Forum 7 11-07-2010 05:38 PM
Knocking noise from the left rear ScotZ WJ Grand Cherokee Forum 9 04-30-2010 02:13 AM
