rear glass defrost strip connector desolder - JeepForum.com
post #1 of 18 Old 02-06-2014, 02:18 PM Thread Starter
Jigsaw404
so my connector that connectors to the rear glass defrost strip desoldered. I tried to solder it to the strip built into the glass but no go, I dont have enough hold. Without replacing the glass, is there a trick to get the connector to stick to the strip built into the glass. I would like to have the rear defrost to work.
Jigsaw404 is offline
post #2 of 18 Old 02-06-2014, 02:35 PM
Double E
Double E's Avatar
JB weld is made of metal, right? I would get some and see if it will OHM to 0 and use it if it conducts.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
post #3 of 18 Old 02-06-2014, 03:46 PM
ThaBeefs
i work at a dealership and we can get copper based ink pen that can fill gaps when the grid gets a cut or scratch ..... not for when the connector brakes from the grid itself we have to replace the glass.
ThaBeefs is offline
post #4 of 18 Old 02-06-2014, 03:57 PM
rdkendrick
2003 WJ
You can buy those at Radio Shack. It's just conductive ink.
Sent from my iPad using my fingers
rdkendrick is offline
post #5 of 18 Old 02-06-2014, 06:16 PM
js12278
You might need a third hand to help out holding it on the connection. Soldering it is going to be the best repair could do.
js12278 is offline
post #6 of 18 Old 02-06-2014, 10:24 PM
rdkendrick
2003 WJ
How do you not crack the window with the heat expansion and contraction?
post #7 of 18 Old 02-07-2014, 12:54 AM
2000_limited
Try the aluminium duct tape from a hardware store. it's strong, super stucky, and metal.
2000_limited is offline
post #8 of 18 Old 02-07-2014, 01:56 AM
losttech
losttech's Avatar
Get a strong magnet stick it on the other side of the window and get some wire thats magnetic or a peice of metal and try to solder it then with the magnet holding the metal agaisnt the window.
A rare earth magnet is really stong and should work.
losttech is offline
post #9 of 18 Old 02-07-2014, 05:08 AM
MadderThanMax
Wj
Yer, I'm in the same boat after repairing the rear door latch and window wiper, I accidentally hit the connector and *Ping* off it came :
MadderThanMax is offline
post #10 of 18 Old 02-07-2014, 05:31 AM
Double E
Double E's Avatar
I like that aluminum duct tape solution too. I got some recently and that stuff is tough... 3M makes what I got (Lowe's).
It would take a little cutting with small scissors and maybe more then one attempt but I think that's the path I would take first.
post #11 of 18 Old 02-07-2014, 06:58 AM Thread Starter
Jigsaw404
Ill try using aluminum duct tape on sunday, let you know. As per the windows cracking, it doesnt. I used a blow torch to get a little bit more heat out of it and without holding it there forever, 1-2 seconds at a time, the windows didnt crack. Anyways, it obvously didnt work with a solder gun,heat gun and blowtorch, so ill just tape it and see.
post #12 of 18 Old 02-07-2014, 08:15 AM
TJSWJ
I've done hundreds of these repairs. Mostly to Ford's, but other brands do it occasionally too. They sell tab repair kits at the parts store, but they are junk. Parts stores don't realize that the kits have a shelf life, so they never switch them out. The repair will last a day or two then fail again. If it does manage to hold, it won't conduct electrical current, and in that case you might as well have used super glue.
This is what you want. http://www.frostfighter.com/index.htm these are by far the strongest, most conductive kit I've ever used.
TJSWJ is offline
post #13 of 18 Old 02-07-2014, 08:36 AM
MWF
Website is down for me at the moment but I hope you can get this stuff in the UK, been looking for something for ages.
MWF is offline
post #14 of 18 Old 02-07-2014, 08:46 AM
TJSWJ
Hmm website works for me. Here is a link straight to the tab repair kit http://www.frostfighter.com/defroste...g-kit-2000.htm
Edit: website shows they do offer international shipping.
TJSWJ is offline
post #15 of 18 Old 02-07-2014, 08:49 AM
MWF
Thanks for this dude!
MWF is offline
