rear-end sagging with load - JeepForum.com
post #1 of 9 Old 09-23-2013, 06:18 PM Thread Starter
docster
The rear end of my WJ sags really bad when towing my boat (tongue weight is only 350lbs). I know I need new shocks. Now will just shocks prevent sagging or do i need new springs? I really dont want to lift it with HD springs if I can avoid it since I have a set of 20inch SRT reps waiting for tires (I know, I know, its a Jeep I should lift it, but that is what the SVT is for). Anythoughts on how to prevent this. Its weird. Same boat on my moms WJ and its perfectly level, and I have seen many WJs towing much heavier loads with more tongue weight and no weight distributing hitch. Whats failed on mine?
2002 WJ Ltd. QD, 4.7L. , Superchips, Magnaflow 12256 muffler and custom 3 inch piping, 2" IRO springs, Procomp 9000 Shocks, JK Moabs, 265/65/17 tires, Moog SS.
Diff fluid change DIY, http://www.jeepforum.com/forum/f310/official-diff-fluid-change-diy-1534883/
docster is offline
post #2 of 9 Old 09-23-2013, 06:28 PM
skain8
skain8's Avatar
Its a spring issue, not shock.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 9 Old 09-23-2013, 08:10 PM Thread Starter
docster
yea, that was what i was thinking. now to find some HD stock height springs? anyone have those?
docster is offline
post #4 of 9 Old 09-24-2013, 06:10 AM
georged
Look into air adjustable shocks. Adding or removing pressure will raise and lower vehicle
georged is offline
post #5 of 9 Old 09-24-2013, 08:41 AM
skain8
skain8's Avatar
You can probably get away with upcountry springs. The guys on here should be able to tell you whether or not they are still available.
skain8 is offline
post #6 of 9 Old 09-24-2013, 10:56 AM
85IrocZ-28
Is there any way to move the load around (move stuff out of the front of the boat to the rear) when transporting? 350lbs is a lot of tongue weight to be pulling down on a hitch that is bolted into a unibody. It can take it, but large bumps in the road could place a lot of strain on things. I am pretty conservative when it comes to putting weight on the hitch of my WJ.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #7 of 9 Old 09-24-2013, 11:04 AM
alfaitalia
Funny. We have a higher towable weight that US spec WJ models (7700lb but this is probably due to people sueing each other over there more than here!) but a lower max tongue weight (max on a UK WJ is 308lb) assuming you are sticking to the US limit.....so yes 350lb is like having two mid sized men stood on your towbar......a bit of sag is to be expected! I try not to exceed 220 for a level tow....also that is the maximum downforce allowed on a UK caravan or trailer tongue.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #8 of 9 Old 09-24-2013, 08:28 PM
bradywgn71
bradywgn71's Avatar
http://www.wjjeeps.com/trailer.htm
6,500-lb tow rating and 750-lb tongue weight rating w/V8 engine.
(w/weight distributing equipment; otherwise 2,000-lb tow rating, 350-lb tongue weight rating.)
So, you're tongue weight is at the max on your factory hitch without a weight distribution set up. You may have seen other WJs towing heavier loads than yours without weight distribution, but that doesn't make it right.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #9 of 9 Old 09-24-2013, 09:21 PM
brouwmat
A weight distribution hitch would help. It made mine sit level when it was stock and I was pulling my camper with it. I don't pull the camper any longer, but if I did, i'd put it back on. I pull the camper with my Yukon XL Denali now with autoride and I still use it with that.
They make them for all size trailers. I got one rated up to 350 lbs by Reese. I think it's called the Mini 350 WD on their website if you want to take a look.
I'd disagree that you should go with stiffer springs.. all that does is leave the weight in the same place (on the rear axle) and it'll wear things out quicker than they should. A weight distribution hitch is different in that it basically turns your trailer and hitch into a lever that distributes the weight to the front wheels as well as the back. It's much easier on the Jeep than any other solution.
brouwmat is offline
