Rear end fluid additive - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Rear end fluid additive
Wheeler Special! Black Steelies w/ 33" Mickey ThompsoROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 02-26-2015, 08:39 PM   #1
mn_anderson
Hi, going to be doing a rear diff flush on the wifes 2000 grand cherokee and was wondering what or if there is a special additive or not? I havnt had any luck finding ones that dont say "Do not use with jeep quadratrac." Just looking for some input.
Thanks
mn_anderson is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 09:17 PM   #2
Jameswj2001
Your quadratrac does NOT require friction modifier (special additive) in the diffs. Varilok axles, which you don't have, were only used in the quadradrive systems and DO require friction modifier (special additive) in the diffs.
01 WJ 4.7 quadra drive 2" bb 245/70/17 grabber at2's
00 XJ 3" lift Wrangler authority 31 10.5 15
Jameswj2001 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 09:26 PM   #3
Louisianaboy
No modifier needed in open diffs. Just may want to check and make sure it is open. It was still an option to get variloc rear diffs on non qd models. But I think it was only on 01 and later models. Just a heads up to check if your not already sure.
The option for 99-00 was trac-lok. Not sure if trac-lok needs additive or not.
Edit. Just looked it up and it's still required on trac-lok.
Louisianaboy is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 09:50 PM   #4
Jameswj2001
http://www.wjjeeps.com/rus/maintenance.htm
