Rear end assembly parts shematic - JeepForum.com
post #1 of 5 Old 05-06-2013, 01:49 PM Thread Starter
scstrick79
Does anyone on here have a breakdown of the rear end assembly of a WJ? My axle went out and I bought a used one from caliper to caliper. Now the decision is whether to swasp the whole thing or just raid the parts....
scstrick79 is offline
post #2 of 5 Old 05-06-2013, 01:57 PM
Darnice
Depends on how your axle "went out". If it was internal to the gearset, then I would do a full swap (assuming the used one is sound), because raiding for parts and getting all the settings and gear mesh just right might be harder. If it was just a bearing or seal, maybe raid for parts.
Darnice is online now
post #3 of 5 Old 05-06-2013, 02:24 PM Thread Starter
scstrick79
It appears that the caliper locked up and over heated the entire thing. I was driving and then there was no power going to the wheel. When I got out and looked under it, the hub and axle housing were glowing red. I can hear the axle turning in the hub but it is not "connected".
post #4 of 5 Old 05-06-2013, 03:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
swap the whole thing. don't even bother opening up the old one.
ratmonkey is offline
post #5 of 5 Old 05-06-2013, 05:47 PM
Swiff
You may be able to change the axles but the ring and pinion are matched sets and will take a good bit of time if you swap over parts. I would swap out whole thing. Also check both assemblies to see if it is posi-rear or limited slip.
Derek
2k JGC Laredo WJ - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
