Rear DS Vibrations - JeepForum.com
post #1 of 2 Old 05-06-2013, 04:12 PM Thread Starter
xkwhx
Rear DS Vibrations
Been reading through allot of the posts on this issue and havent quite found the golden solution yet.
My Setup:
2004 WJ Limited with QuadraDrive
Claytons 4.5 LA lift
NP247 Transfer Case with tailshaft swap from Barnett Performance (essentially a SYE)
New Drive Shaft (CV style) Spicer joints
My Symptoms
Driveline Vibes specifically at 35-50Mph
Dissipates at 50-60ish (sweet spot right at 60-63)
Returns from 60ish up
Hard acceleration from 0-35 makes no difference there are no vibes here
My Solutions I have tried
Originally had the stock slip yoke in rear, vibes were much more pronounced and at all speeds. Switched to the new tail shaft and new DS and fixed about 85% of the vibes
All tires rotated and balanced
All bushings, bolts, links checked and tight/OK
Full 4 wheel alignment (twice) - once right when lifted then again about 6 months later
Rear pinion seal and rear bearing new within the last 16 months
Confirmed it is the rear DS as I have puled the front DS and tested with same results
Pulled rear shaft and had re-tested for balance
Axles pulled and checked for straihgtness
Any further ideas greatly welcomed. I am wondering if I should be looking at the T-case and possibly the output shaft bearing as I am out of ideas and that is the only thing left.
xkwhx is offline
post #2 of 2 Old 05-07-2013, 05:03 AM
skain8
skain8's Avatar
Pinion angle most likely . What are your angle specs?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
