Rear diff question - JeepForum.com
post #1 of 10 Old 09-16-2013, 10:28 AM Thread Starter
AIRBORNE
Rear diff question
I'm sorry if this is an old question. I have been going over the entire WJ, and all fluids look really good EXCEPT the rear end. It was darker than the front diff (noticeably) so I want to swap it out. Any tips on the process (special tricks or steps) or suggestion of what fluid to put in would be appreciated. Also, is that little rubber stopper something that seems to be problematic about seeping (leaking)? Just curious if it's something to replace and keep the old one for spare.
2000 Grand Cherokee Limited/ Quadra Drive / 4.0L/ OME HD springs, Bilsteins, JKS trackbar, 255/75/17 BFG M/T with JK Moabs
2005 Silverado 2500 HD Duramax
United States Army (2004-present)
AIRBORNE is offline
post #2 of 10 Old 09-16-2013, 11:31 AM
Ravie
It is a more complete process to take the pumpkin off so you can wipe out the cover and clean of the metal from the magnet. As far as sealant goes...someone else may have a better suggestion, I used RTV and I'm not sure it did so great.
Yes, those covers get harder over the years and replacing it wouldn't be a bad idea. Mine seeps all the time...
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #3 of 10 Old 09-16-2013, 12:27 PM
MattJeep
2003 WJ
Definitely take the cover off to clean. Get a couple cans of brake cleaner and blast the **** out of everything. The whole inside including ring and pinion should be nice and clean. Then get a new diff gasket, should be dana 35 if you have a rubber plug. Then refill. Think 75-90 for a 35.
MattJeep is offline
post #4 of 10 Old 09-16-2013, 12:32 PM Thread Starter
AIRBORNE
Do they make covers with a threaded peep filler hole?
AIRBORNE is offline
post #5 of 10 Old 09-16-2013, 12:37 PM
MattJeep
2003 WJ
Dunno. I think so. Type "dana 35 cover" on ebay.
MattJeep is offline
post #6 of 10 Old 09-16-2013, 01:01 PM
85IrocZ-28
D44 HD also has a rubber plug.
If the diff is a perfect oval, it is a D35.
if it is larger on the ring side (not a perfect oval), you have the D44HD.
The rubber plug could be the same though.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #7 of 10 Old 09-16-2013, 07:10 PM
MattJeep
2003 WJ
Ha, ya I just noticed that today. Thanks for correction.
MattJeep is offline
post #8 of 10 Old 09-16-2013, 07:41 PM
2004DUB
As far as fluid I went with lucas 75w140 synthetic when I changed my front and rear in my 04 with d30/d35 and it quieted down my rear bearing noise and slowed a front left axle seal leak a good bit. I just pull the covers clean them out well with brake clean blow it out with a air gun, clean the gasket material off and throw black rtv back on.
2004DUB is offline
post #9 of 10 Old 09-16-2013, 07:54 PM Thread Starter
AIRBORNE
Good advice guys. Thank you.
AIRBORNE is offline
post #10 of 10 Old 09-17-2013, 05:03 AM
losttech
losttech's Avatar
This place makes stock size covers with drain plugs and threaded fill holes.
http://stores.hi-potek.com/-strse-JE...Categories.bok
One of the only places I could find for the dana44a also as a fellow forum member pointed out.
I bought a set but have not had the time to install them.
Some wont like the drain plugs some will, I like them and wanted to make it easier to do the drain and fill on my diffs.
losttech is offline
