rear diff ... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > rear diff ...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 08-27-2010, 06:28 AM   #1
browning
rear diff ...
1989 grand cherokee auto..5.9 motor ..was backing up and rear diff. made a crunching sound ..checked the oil in diff. and it was black ..i drained the oil and replenished it with 80w90 synthetic oil ...noise in diff. went away so far so good ..[is this a common problem ???? ]
bone collector
browning is offline   Reply With Quote
Unread 08-27-2010, 07:02 AM   #2
GrouchyTim
Was there anything on your magnet? Did you do any work in the previous few thousand miles that you may have left something in the pumkin? (once found a flashlight battery in one-that was interesting) No that isn't common and you may want to pull the diff cover and visual inspect the gears. Check your tooth markings and backlash and pinion teeth.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
GrouchyTim is offline   Reply With Quote
Unread 08-27-2010, 05:23 PM   #3
browning
i did not remove the diff. cover i siphoned the oil with my vacuum pump ...and replenished it with new oil ..i know i should have removed the cover and cleaned everything ...lets wait and see ...
bone collector
