Rear D44 pinion seal replacement - JeepForum.com
post #1 of 13 Old 07-07-2014, 02:04 AM Thread Starter
kjjohn95
So, in addition to my weird clicking brakes and possible bad cv axle, I also have a leaky rear pinion seal. I'm pretty sure I have the Dana 44 (its a 4.7 w/ quadradrive). I plan on doing it myself, but I'm not sure which seal to buy. Morris 4x4 has two: http://www.jeep4x4center.com/pinion-...5012847aa.html and http://www.jeep4x4center.com/pinion-...-44-47885.html. Which one is it? Also, will a 230 ft-lb electric impact gun be able to remove and re-tighten the pinion nut? I plan to measure preload before I do it as well.
Edit: I have driven around for quite a while with low diff fluid. If it leaks to the bottom of the seal then stops leaking, is there still enough fluid inside to safely lubricate the diff?
kjjohn95 is offline
post #2 of 13 Old 07-07-2014, 12:15 PM Thread Starter
kjjohn95
Anyone?
kjjohn95 is offline
post #3 of 13 Old 07-07-2014, 06:43 PM Thread Starter
kjjohn95
Bump
kjjohn95 is offline
post #4 of 13 Old 07-07-2014, 09:21 PM
stone white 99
Your impact will work on removal only.
I did an outer front pinion seal on the front axle and had good results by marking the nut and pinion threads with a scribe. You have to tighten the nut to as close as where it was before. I used a mega pipe wrench to hold the yoke and a big azz breaker bar to tighten the nut. 50k miles later the pinion and ring gear are still happy.
stone white 99 is offline
post #5 of 13 Old 07-07-2014, 10:31 PM Thread Starter
kjjohn95
Ok, sounds good. Which seal should I buy out of the two above? They look different, but on the dana 44 exploded diagram they show as the same part.
kjjohn95 is offline
post #6 of 13 Old 07-11-2014, 04:17 PM Thread Starter
kjjohn95
Does anyone have an answer to my first question? I really don't want to buy the wrong seal.
kjjohn95 is offline
post #7 of 13 Old 07-11-2014, 08:11 PM Thread Starter
kjjohn95
Anyone? I really need to know before I order this.
kjjohn95 is offline
post #8 of 13 Old 07-12-2014, 01:17 AM
Thomahawk
You know you have the Dana 44A (aluminum), right?
Wranglers uses the Dana 44,,,
AND its NO GOOD for your diff to be running low on fluid IMO.
Buildthread
Thomahawk is offline
post #9 of 13 Old 07-12-2014, 12:24 PM Thread Starter
kjjohn95
I know that it's not good for it to be low on fluid, I am keeping it topped off until I replace the seal. Do you know which of the seals that I listed above is the right one?
kjjohn95 is offline
post #10 of 13 Old 07-12-2014, 12:52 PM
jetrinka
Sometimes pinion seals are difficult to track down, as far as getting the right one. I'd either give that company a call or go to a local parts store and look for a National seal or other good brand. Then if its wrong you can take it back, with the old one and match it up to what you need.
jetrinka is offline
post #11 of 13 Old 07-12-2014, 01:13 PM Thread Starter
kjjohn95
Okay, none of my local parts stores have seals for the dana 44, I may just order both seals on Morris 4x4 or quadratec, then return the wrong one
kjjohn95 is offline
post #12 of 13 Old 07-22-2014, 10:49 AM Thread Starter
kjjohn95
Okay, I have one more question. I just replaced the seal, and torqued the nut until it measured about the same rotational torque in inch pounds that it was before. My only question is: does the rear dana 44a in the wj have a crush sleeve? I've heard a lot of people say that 44s have shims instead, but on the Morris 4x4 diagram, it shows a "collapsible spacer"
kjjohn95 is offline
post #13 of 13 Old 07-23-2014, 02:37 AM Thread Starter
kjjohn95
Anyone?
kjjohn95 is offline
