Rear Brake Question - JeepForum.com
 2Likes
  • 1 Post By UnknownIPandID
  • 1 Post By grussell
post #1 of 10 Old 07-09-2016, 08:50 AM Thread Starter
UnknownIPandID
Rear Brake Question
Hi all,
My rear right brake caliper mounting bolt (the 18mm one connecting mounting bracket to axle) is stripped into oblivion. I can either replace the assembly or repair the hole.
My problem is I don't even know what you would call the replacement assembly, I don't think it would fit under the category of knuckle or spindle (as the front would). If so I'm not finding anything for it under those names.
If I were to repair the thread, I would use Heli-Coil 554612 M12 X 1.75. Does this seem correct?
Please forgive my ignorance as I have searched for quite a while and found 99% of it being front brake related.
Any advice is greatly appreciated,
Thank you!
-Mat
UnknownIPandID is offline
post #2 of 10 Old 07-09-2016, 09:18 AM
losttech
losttech's Avatar
losttech is offline
post #3 of 10 Old 07-09-2016, 08:04 PM Thread Starter
UnknownIPandID
Hi,
That is the bracket I'm referring to(but right side), but it is bolted onto the actual axle which is where the thread that is damaged is. Not the bracket itself is damaged. I could take a picture if it would help!!
Thank you!
Mat
post #4 of 10 Old 07-09-2016, 11:04 PM
ak_wj
I would re-tap it to a common thread. A local shop boogered mine up and I was able to chase them clean, but contemplated replacing that same part. It looks like you have to take the axle apart just to get to it.
ak_wj is offline
post #5 of 10 Old 07-10-2016, 07:08 AM
grussell
A picture would help. Here is a diagram of the rear axle, so not sure what you are referring to.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #6 of 10 Old 07-10-2016, 09:12 AM Thread Starter
UnknownIPandID
Hi,
I uploaded a picture, sorry I can't be descriptive enough!
I'm glad to see the part I'm referring to does detach from the rear axle, I would just need the name for it! Kind of silly of me to think that it wouldn't.
In the picture you can see the bolt i'm referring to is the large one in the center. The side closest to the bottom is the brake caliper bracket, and the side furthest from the bolt is the part that is where the threads are/ were.
Would there be any drawbacks to drilling and tapping to a common size?
I've provided a google drive link in case my attachment for whatever reason didn't upload correctly.
https://drive.google.com/file/d/0B8h...ew?usp=sharing
Thank you for the help, much appreciated!
-Mat
post #7 of 10 Old 07-10-2016, 11:41 AM
Dan_in_MN
Originally Posted by UnknownIPandID View Post
Hi all,
Thank you!
-Mat
I take it you're asking about the bolt circled in red? I'm also thinking you're asking about where the bolt threads in where it's circled in green. Correct?
If my thoughts are correct, I would personally repair the thread. I would think the bolt is of a particular grade/hardness/toughness and not just a common bolt.
2000 WJ Grand Cherokee Black 236,000+ miles
Needs: Left rear wheel bearing. Front right CV joint.
Dan_in_MN is offline
post #8 of 10 Old 07-10-2016, 12:15 PM Thread Starter
UnknownIPandID
Hi,
You are correct, this is the bolt I'm referring to. The green is where the threads are located.
So you're saying you would heli-coil it? I was going based on what ak_wj and would drill it to a slightly larger size, tap it to something common, and find a bolt with the same hardness.
Thank you!
-Mat
Dan_in_MN likes this.
post #9 of 10 Old 07-10-2016, 02:36 PM
Dan_in_MN
Hi,
Thank you!
-Mat
Mat
That should work too! Post back with your progress! I haven't had my brakes apart. YET I need to replace a rear wheel bearing. So, my time is coming soon!
post #10 of 10 Old 07-11-2016, 01:35 PM
grussell
Drilling and re-threading would work just fine. The bolt hardness should be stamped on the head.
grussell is offline
