Rear brake caliper install - JeepForum.com
post #1 of 6 Old 11-07-2013, 04:46 PM Thread Starter
heitzman
2002 Jeep Grand Cherokee, Can anyone tell me how to install the spring/ clip that is on the outside edge of the rear calipers? Thank you
heitzman is offline
post #2 of 6 Old 11-07-2013, 09:28 PM Thread Starter
heitzman
Can anyone help me please?
heitzman is offline
post #3 of 6 Old 11-07-2013, 10:10 PM
ronj35
This part can be tricky. I dont know of a tutorial or a video to show you but essentially you're trying to install the clip one half at a time. Start by putting one part of the clip in the hole in the caliper and then flex/rotate the clip to get it to seat in the other hole by hand or with pliers. It can help when putting the clip into the second hole to lightly tap the clip into the hole with a hammer and then bend the "ear" to its final resting place on the caliper bracket. Use the front brakes or the other side of the rear brakes as a reference too, so you know how the clip should look when its seated properly
ronj35 is offline
post #4 of 6 Old 11-08-2013, 08:33 AM
ChrisHager
Administrator
ChrisHager's Avatar
Brake Rotor and Pad Install
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 6 Old 11-09-2013, 10:38 AM Thread Starter
heitzman
Thanks guys. I did one end of the clip/ spring and put the the other end in the hole and used a large C-clamp to hold it in and pried the clip/ spring into position with a screw driver.
heitzman is offline
post #6 of 6 Old 11-09-2013, 11:08 AM
mycreativename
I've always just used needle nose pliers. The clips have never been even remotely too difficult to do that way.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
