-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Rear brake caliper install (http://www.jeepforum.com/forum/f310/rear-brake-caliper-install-1768650/)
heitzman 11-07-2013 03:46 PM
2002 Jeep Grand Cherokee, Can anyone tell me how to install the spring/ clip that is on the outside edge of the rear calipers? Thank you
heitzman 11-07-2013 08:28 PM
Can anyone help me please?
ronj35 11-07-2013 09:10 PM
This part can be tricky. I dont know of a tutorial or a video to show you but essentially you're trying to install the clip one half at a time. Start by putting one part of the clip in the hole in the caliper and then flex/rotate the clip to get it to seat in the other hole by hand or with pliers. It can help when putting the clip into the second hole to lightly tap the clip into the hole with a hammer and then bend the "ear" to its final resting place on the caliper bracket. Use the front brakes or the other side of the rear brakes as a reference too, so you know how the clip should look when its seated properly
ChrisHager 11-08-2013 07:33 AM
2 Attachment(s)
Brake Rotor and Pad Install
heitzman 11-09-2013 09:38 AM
Thanks guys. I did one end of the clip/ spring and put the the other end in the hole and used a large C-clamp to hold it in and pried the clip/ spring into position with a screw driver.
mycreativename 11-09-2013 10:08 AM
I've always just used needle nose pliers. The clips have never been even remotely too difficult to do that way.
The time now is 02:56 AM.
