The real cost of a 4 inch lift - JeepForum.com
post #1 of 16 Old 08-11-2011, 09:46 PM Thread Starter
holder14
I am going to be lifting my 01 wj here soon. I am looking at either getting a IRO 3 inch and leaving it at that or going with an IRO 4 inch kit and spending some money. I am considering either one of the kits below for a 4 inch kit.
I would buy new adjustable arms with this kit:
http://www.ironrockoffroad.com/Merch...egory_Code=PFW
Would get adjustable long front long arms:
I know its not gonna be just bolt this up and go wheeling. I know i will need a new steering stabilizer and driveshaft, but what are the hiden or out of mind things you have to buy to make everything work. How much did you guys end up spending after its all done on your 4 inch lifts? thanks a lot in advance
holder14 is offline
post #2 of 16 Old 08-11-2011, 10:36 PM
straty1987
-people add the addco rear sway bar to help with body roll with greaseable bushings so you font get a clunk. around $165
- check to see if your tie rods are worn/loss, if so those will need replacing.
- if your front drive shaft has a boot on either end at 3" or 4" it will need to be swap. if not at 3" you will be good.
- for the steering stabilizer you can get one fore $55 and under like the rough country or the moog one.
- might want to look into coil isolators (things that hold your springs) sicne tehy wear after time and cause our jeeps to lose 1/4" to 3/4" of height. all 8 can run $100 shipped from roackauto
i just did the rusty 2.5", MX6 shcoks, addco rear sway, new coil isolators, and bigger tires . then went on a trip to PA over 160 mils one way to go off roading and did not have a problem. but my front drive shaft is good for up to 3" and i still have have part to add.
you can have no problem or go nuts trying to replace parts to get ride of a death wobble. at 4" i belie you need more then just shock and springs, i think its teh control arms have to be longer.
straty1987 is offline
post #3 of 16 Old 08-12-2011, 08:03 AM
tbone1004
The SS can be had with the IRO kit, and HIGHLY recommended. Email Kolak as you most likely need new tie rod ends and coil spring isolators. If not, it's $250 for peace of mind against death wobble. Highly recommend the adjustable trackbar in the IRO kit
You don't need long arms at that height unless you are after lots of flex. I.e. rock crawling etc. I'm not so I didn't need them. I did my lift for load hauling and because my springs were dead. All depends on what kind of off roading you plan on doing...
tbone1004 is offline
post #4 of 16 Old 08-12-2011, 08:11 AM
tsconver
2003 WJ
4" gets expensive, if you want good ride quality you need long arms, even adjustable short arms are at a pretty steep angle and transmit a lot of road vibes back to the jeep where long arms are at much less angle and do not transfer those vibes.
At 4" you need new shocks, adjustable control arms all around or perferably long arms in the front, a arm spacer in the rear, adjustable track bar, double cardan front driveshaft, tight components (tie rod ends, ball joints, wheel bearings) and those are just the minimum.
huh? lift for load hauling? Lifting a vehicle to haul is stupid, if anything you reduce your towing capacity by lifting as you are changing all of the geometries and impacting force distribution.
Also at 4in of lift long arms are highly reccomended no matter what you intend to do if you want a near stock ride.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #5 of 16 Old 08-12-2011, 08:26 AM
FirefightinWJ
Addco sway bar is not necessary. Sure it's nice, but you don't NEED it. Also, a Monroe SS will be more than adequate.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #6 of 16 Old 08-12-2011, 08:27 AM
FirefightinWJ
I'm at 120k...50k+ have been at a lifted height -- either 2", 3", or 5.5". At my current height, 5.5", I've never had DW and I am running original TREs and BJ's -- both of which are still tight.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
-Devin
post #7 of 16 Old 08-12-2011, 09:49 AM
r_kelly252
damn original bj's and tres huh...
well if you got the coin for the 2nd kit being long arm do it up. its pretty complete.
i do recomend bilstiens for shocks though.
just like firefighting said addco isnt necessary but i have one and i do like it on the highway/towing.
i got my steering stabilizer from kolak... $60 ish shipped and it is a moog one. very very beefy compared to even a Rough country one. iro has a auxiliary one (on their website thats what they called it) where it mounts between your trac bar and drag link. i have purchased it but never put it on... silly i know but i did tre and alignment and im not screwing with that **** just for a ss i dont need on right now.
but it def looks like it would dampen the bump steer better than one in the stock location
r_kelly252 is offline
post #8 of 16 Old 08-13-2011, 09:45 PM Thread Starter
holder14
Well i just decided to go with the 3 inch lift from IRO. I ended up getting the DT8000 shocks with the bump stops, the adjustable trackbar, and i ordered some zone offroad front sway bar links. I wont ever probably disconnect jks quicker disco's if i bought them anyway so i figured i would save a little money there and just get some good links. I also bought a kevins offroad brand steering stabilizer. I know that means three different companies for my lift but thats ok with me so i can get exactly what i want.
Now to decide on tire size. I Am thinking 265/75R16's based on the recomendations on IRO's website saying they will clear with the DT8000 shocks, but am wondering if thats true. If i dont get the 32's(265/75) i will get 31's(265/70R16) What do you guys think as far as tire size?
holder14 is offline
post #9 of 16 Old 08-13-2011, 09:51 PM
AL04WJ
I've been there with IRO 3" and 265/75R16 tires, they just plain don't fit.
Julian
2004 Laredo 4" lift, 265/75/16 Duratracs, JCR Stage II sliders, ARB bumper and XD9000
AL04WJ is offline
post #10 of 16 Old 08-13-2011, 10:15 PM Thread Starter
holder14
ok well i will get some 265/70R16's. That one extra inch wont make a huge advantage for me, and the smaller (31's) tires will fit a whole lot better so that is the size i will go with. I do wanna be able to wheel it afterall without ripping off my bumper.
holder14 is offline
post #11 of 16 Old 08-13-2011, 10:16 PM
WJ2000
Thats for sure'' you dont need a rear swaybar, Ive been running my WJ
for over a year now with out it, and really I dont even miss it
Really man'' try it for a week. ''wheres''your sense of adventure'''
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #12 of 16 Old 08-13-2011, 10:58 PM Thread Starter
holder14
Im just gonna be running the stock sway bar. Maybe down the road i will upgrade it, but thats after the other things i have planned for the Dub J
holder14 is offline
post #13 of 16 Old 08-13-2011, 11:29 PM
straty1987
i would run without one but i load the top of the jeep things like Sheetrock and plywood for project and duing turns and when windy i can fell the roll. with the bigger sway bar it helps allot.
also when driving fast and turning a tight corner it help.
post #14 of 16 Old 08-14-2011, 12:14 AM
alwaysHI
2003 WJ
265/75/16 will fit only if using stock wheels and stock backspacing (no wheel spacers). it'll cost a little trimming, but BigV on here is running 32" KM2's with IRO 3" lift.
just saying...
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #15 of 16 Old 08-14-2011, 12:23 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I've run without both bars, with just the rear, with just the front, right now I am running discoed on the street because my stupid Rough Country discos clunk so much I went insane. I prefer the bars connected, but offroad I REALLY prefer to disco. I think I will wind up extending some stock end links like I did for the rear and just unbolt them when I want to go wheeling.
Anyway...yeah even with a 2" lift its easy for the costs to skyrocket.
BDS Springs $237
Bilstein Shocks $310
3/4" spacers $25
JKS QDs (didn't like) $146
JKS track bar and tie rod $272
RC QDs (don't like them either) $69
Sold used JKS QDs -$75
So I'm about $1000 into a hybrid 3" lift, but man it drives/tows/wheels nicely. It is just as easy to do the same with a 4" lift if you add in the cost of a driveshaft, add in upgraded track bar/tie rod/drag link (definitely a MUST-HAVE on the tie rod IMO) and any quick discos, additional adjustable arms, shock upgrades, and any replacement parts you might need.
~Richard
billzcat1 is offline
A 4 inch suspention lift and a 2 inch body lift. Could that suport 36inch tires? Calpatt WJ Grand Cherokee Forum 27 04-26-2011 05:17 PM
WJ ~ 6 inch lift : Which one to buy? CWDM WJ Grand Cherokee Forum 20 02-14-2011 04:30 PM
How much does it cost to install a 4" rough country lift on a wj Ljohn221 WJ Grand Cherokee Forum 14 02-08-2011 07:43 PM
4 inch teraflex lift vs IRO 4inch lift??????? anden02 WJ Grand Cherokee Forum 50 11-01-2010 10:46 AM
245/70/16 on ~3 inch lift wj_jeep92 WJ Grand Cherokee Forum 3 09-27-2010 03:43 PM
