RB1 issue thats driing me crazy - Page 2 - JeepForum.com
post #16 of 26 Old 02-08-2014, 02:21 PM
Bermuda39
RB 1 Disc Error
Thanks for all the input on RB1 radio......I have tried all but failed what is my next step that would not be so expensive.
I have bought a new Nav disc, the last release Part # 05064033AL from 2013 on ebay, then I cleaned the lens with alcohol and q-tips and then used compressed air in the unit which was very clean and my last attempt was to buy a DVD/CD lens cleaner. I still have the same problem from when I started out......*Reading disc error message* What would be my next step before I purchase a new unit. Please help me out. Thanks !
Bermuda39 is offline
post #17 of 26 Old 07-23-2014, 07:19 AM
Modeler
Thank you to those that came up with this and a special thanks for the above photo. I forgot to take one as I was disassembling mine.
I found an easier method to hold the lower of the three pieces up while reattaching them together, thread. I took a long length, about 20" or so and taped it to the rear surface of the unit. I then threaded through the little slot on the end opposite the screw and then back under the raised area where the screw goes. I taped the free end to the back of the unit as well. I inserted the lower metal piece through the opening and kept hold of the thread "loop" that was on the side towards the front of the radio. Keeping tension on the thread kept the piece up and allowed me to add the black plastic disk, insert the top metal part and then screw the assembly together.
I quick test showed that it is, at least for now, back to a working state.
Again, thanks all.
Speed costs money, how slow do you want to go?
Modeler is offline
post #18 of 26 Old 10-04-2014, 01:09 PM
fiveseven15
Is the screw at the 6 o'clock position in the picture above? I got that far but after that couldn't figure out what to do. I wasn't sure what should or shouldn't come off. I blew some dust out and it seems to work okay now but I'd rather do the proper cleaning
fiveseven15 is offline
post #19 of 26 Old 06-28-2015, 10:49 PM
tcmault
Any more updates?
2006 AEV Unlimited Rubicon. Silver. 6-speed. 255/85R16. OME ZJ/LJ. Nth TT. Alloy Shafts.
tcmault is offline
post #20 of 26 Old 02-10-2017, 05:26 PM
jim9006
Originally Posted by BransJeep View Post
FIXED! for any one that is interested in fixing thiers it can be done..it take some patience and a little know how. I figured i might as well try to see whats wrong so what i did was take the face off the radio..then the top casing..about 8 phillips screws.
then you have access to the cd slot and drive motors etc...there is four phillips screws the hold this unit in plce. remove them...then with a flashlight locate where the laser sits..use a q-tip with a little windex on it and clean the laser...i had a noticable amount of filth on mine..then with a dry q-tip polish it up and reinstall...it has worked all day today with no isues at all and even plays the cd's faster hopefully this works for others if they try it
Warning thread resurrection:
Just did this to my RB1 and it worked like a charm. Nav. now works better, loads faster than it ever has. FYI: you’re going to need a good set of jewelers screwdrivers.
jim9006 is offline
post #21 of 26 Old 02-10-2017, 07:39 PM
xcaliber81
I'm curious as to why people are still using the RB1? My alpine has very good sound quality and in my experience factory radios always suck for sound quality.
xcaliber81 is online now
post #22 of 26 Old 02-10-2017, 10:36 PM
jim9006
I'm pretty sure the RB1 is an Alpine.
jim9006 is offline
post #23 of 26 Old 02-11-2017, 09:22 AM
xcaliber81
Interesting, how does it compare to today's alpines?
post #24 of 26 Old 02-11-2017, 10:29 AM
jim9006
All I know is it sounds better than the stock one that came with my WJ. A lot better....
jim9006 is offline
post #25 of 26 Old 02-11-2017, 10:34 AM
xcaliber81
So switching from my aftermarket alpine to the RB1 would it be a downgrade?
post #26 of 26 Old 02-11-2017, 11:01 AM
jim9006
Only you can answer that.
jim9006 is offline
Goin crazy CBates75 WJ Grand Cherokee Forum 12 10-28-2010 08:22 PM
Crazy O2 sensor issue, very confusing please look! JAC1502 WJ Grand Cherokee Forum 15 07-16-2010 11:00 AM
4.7 Won't Start. Gauges going crazy. Islesfan079 WJ Grand Cherokee Forum 5 06-29-2010 12:25 PM
Jeep shakes like crazy bassfisher999wj WJ Grand Cherokee Forum 13 05-20-2010 04:10 PM
Got some crazy OBD II readings steelstr45 WJ Grand Cherokee Forum 40 04-08-2010 06:34 PM
