Rattle/Grind after long uphill climb (4.0 WJ with 242) and p1494 code - JeepForum.com
post #1 of 7 Old 07-04-2013, 05:42 PM Thread Starter
lesterpolfus
Hey folks,
I have a 2001 WJ Laredo with the 4.0 I6, and the 242 transfer case, with 127K miles.
I had the transmission rebuilt last year by a very reputable shop in town. It's run great ever since.
I live in South West Washington and it has been very hot here, twice we've experienced the following:
After a very long, steep uphill climb on forest roads (like gaining 2,000 feet of elevation in about 4 or 5 miles) the Jeep makes a grinding/rattling noise from the transmission or transfer case. Both times the Jeep was in 4 Full Time.
The first time my wife was driving with a friend and I wasn't in the car to hear it. For those of you that know the area, it was the road up to Silver Star mountain, and it was about 90 degrees out.
The second time I was driving, air temps were lower, in the high 70's or low 80's. Engine temp was right at 210, which is a little high for my Jeep, but it seemed reasonable, since we'd been doing a long uphill climb for several miles. I heard a grind/rattle from the transmission or transfer case area, that coincided with giving the Jeep more gas,and it didn't seem to want to respond to the throttle.
This was right before the summit of the road we were on, so we got outside, turned the car off and let it sit for a few minutes. It was fine the rest of the time.
All the fluids look good, and there's no leaks, hot smells etc.
Also, I've had an intermittent P1494 Leak Detection Pump code for the last couple weeks. I've made a cursory examination of my vacuum hoses, but haven't really dug into it.
Any thoughts?
Regards,
David
lesterpolfus is offline
post #2 of 7 Old 07-05-2013, 12:06 AM
cykaaro
First thing to come to mind, is how is your front driveshaft? More particularily the t-case side? If it is the rezeppa, is the boot ripped? That's the first place I'd look. Also what's the fluid in the t-case like?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 7 Old 07-05-2013, 06:36 AM
rcwj04
Mine did that, now it's blown to hell. Chain is stretched, possibly even off of my gears. I'd say the transfer case is the problem. Mine did it when ever I was in 4wd and the tires spun a bit. Try to change the fluid maybe you will get away lucky.
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #4 of 7 Old 07-05-2013, 09:28 PM Thread Starter
lesterpolfus
All looks good under the Jeep, boots and drive shafts look fine. No leaks. We just moved house so I can't find what I need to open up the transfer case, I'll locate it in the next couple days. The T-case fluid was changed out two years ago when I bought the Jeep.
Thanks for the help folks. If anybody else has ideas I'd love to hear them.
post #5 of 7 Old 07-07-2013, 03:59 PM Thread Starter
lesterpolfus
Hey guys,
The transfer case looks fine. I ran the Jeep up another hill yesterday, and got a little more info. The noise sounds like its coming from the tranny, gets better in Neutral, and goes away in Park, so tomorrow I'll be giving the rebuild guy a call.
Thanks,
David
post #6 of 7 Old 09-16-2014, 10:15 PM
JustSomeDude
Did you ever figure out what the noise was?
2004 Jeep Grand Cherokee Laredo
3" IRO Lift Kit | Bilstein 5125 Shocks | JKS discos | JKS BPEs | IRO Adj Track Bar
Goodyear Duratrac 265/75/16
JustSomeDude is offline
post #7 of 7 Old 09-20-2014, 09:49 PM Thread Starter
lesterpolfus
Yep.
Everybody else was right. The transfer case was shot. That coupled with the fact that every time I drove the Jeep something else broke, made me fall rapidly out of love with it.
Traded it in on a 2001 Ford F150 Supercrew 4x4 in August of last year, haven't looked back since...
