Random stall, low idle, no codes - JeepForum.com
post #1 of 7 Old 01-19-2013, 07:07 AM Thread Starter
outofrng623
Thanks for looking...
04 JGC 4.7 no mods
Yesterday, sitting at a light, heat on, nothing else, car slowly dropped in idle and stalled. No CEL, no codes, notta. Started right back up. I pulled over, sat for a while and it acted fine. Drove for 5 minutes, parked, sat there for about 5 minutes and the idle dropped to under 500 and then it caught itself and went up to 650. I think if I were in gear, it wouldve stalled. Happened one more time driving home, but I tapped the gas before it stalled because I was sitting at a light with traffic behind me and I didnt want to be "that guy".
TPS has checked out fine, has new plugs for a while now, new air filter, new fuel filter, battery is good, alt is good, IAT checked out ok with resistance check, a quick IAC check came out ok, removed, idle went up, back on, reverse, steering and AC and it barely changed in RPMS, checked for vac leaks by spraying cleaner. O2 sensors all appear to be operating properly. There is only one thing that I noticed that was slightly weird to me. When my jeep is idle the TPS shows it's at 11% which is normal (WOT it shows almost 80%, also normal), but when this issue happened (not the actual stall, wasnt monitoring then) my TPS reported 7.8%, voltage dropped as well as RPMs.
Thoughts?
Would a drop in RPMs change the throttle position at idle? I wouldn't think so? I would think the problem is the TPS or IAC But, what do I know?
thanks
outofrng623 is offline
post #2 of 7 Old 01-19-2013, 09:10 AM
99SK04GTX
Clean your throttle body
99SK04GTX is offline
post #3 of 7 Old 01-19-2013, 09:21 AM Thread Starter
outofrng623
That's today's plan. Just odd that its so random.
post #4 of 7 Old 01-19-2013, 09:30 AM
imaguy3
doesn't hurt to check battery connections too. Last week I got gas, went to restart car and as soon as I put in gear it stalled. Gave it a sec. and then it started right back up. When I got home and was looking over things I noticed my negative terminal had worked loose enough that it would rotate a little on the post. Tightened it back up and all's been well.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #5 of 7 Old 01-19-2013, 09:32 AM Thread Starter
outofrng623
I actually just changed mine about two weeks ago and did check them just in case...all good.
post #6 of 7 Old 01-19-2013, 02:50 PM Thread Starter
outofrng623
So, went to clean the iac and it fell right apart. It was covered in chunks and grime. Had to get one from the stealership. Also got a new Pcv. Dumped a whole can of tb cleaner, let it sit for a few hours. Put it all back together, too soon to tell if the problem still exists or not but I can tell you this...my throttle position at idle is now 0.5% lower and my wide open throttle has gained 5%. This is sure to improve gas mileage. More to come as time goes by...
post #7 of 7 Old 03-23-2013, 09:47 PM Thread Starter
outofrng623
Wow. Forgot about this thread too. I have a tone of info on another thread. 6mpg, check my username for that thread.
