Random no start with total power loss - JeepForum.com
post #1 of 3 Old 07-27-2010, 02:35 PM Thread Starter
dougy147
This has happened several times now always on a hot day after the jeep has been driven for a 1/2 hour or so. Shut it down and go to start it a few minutes later and nothing...no power to anything. Try again a few minutes or even a few seconds later sometimes and it starts up with the time reset, so it seems like it's totally loosing power.
I'm thinking ASD relay maybe? Would that cause this total power loss? I found a lot of posts related to the ASD for ZJs and XJs but nothing really for a WJ. Any ideas are appreciated!!
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #2 of 3 Old 07-27-2010, 05:26 PM
Double E
Double E's Avatar
Had the same thing happen recently. I disconnected the battery to clean the terminals, suspecting corrosion and there was none. Hooked it back up and all things lit up like it never happened. Only happened once...so far.
What's the ASD?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 3 Old 07-27-2010, 06:04 PM Thread Starter
dougy147
I was thinking of doing the same, I guess it can't hurt.
ASD is Automatic Shutdown Relay. Power for most things goes through it, but i'm not sure if EVERYTHING does. I have a factory service manual but we moved recently and I haven't been able to locate it. I should be able to figure it out from the wiring schematics....maybe.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
42re total fluid loss gomes512 ZJ Grand Cherokee Forum 5 01-03-2010 11:34 PM
4.0 random misfire and loss of power WJFreedom ZJ Grand Cherokee Forum 3 12-28-2009 11:26 AM
'98 5.2 ZJ long start and power loss Fixxxer_ZJ ZJ Grand Cherokee Forum 1 09-11-2009 12:58 PM
think they will total loss my wj? ( accident ) alecmcmahon ZJ Grand Cherokee Forum 65 03-06-2008 07:50 AM
Temporary Power Loss after Start-up - 99 Grand Cheokee V8 cc-rider ZJ Grand Cherokee Forum 14 10-05-2006 03:18 PM
