Random Misfire - What else can i fix!? - JeepForum.com
post #1 of 8 Old 04-13-2011, 09:00 PM Thread Starter
enjoithis
Question Random Misfire - What else can i fix!?
I have a 99 Grand Cherokee Limited, v8 with 160k miles on it
I continue to get codes P0202 -0207
So far I have changed injectors, throttle position sensor, fuel filter, and spark plugs. The issue is very intermittent, it seems to drive fine for the first 5-10 minutes every time, and then it starts to misfire badly. It will also go away after driving for some time, and randomly come back again. Any suggestions?
enjoithis is offline
post #2 of 8 Old 04-14-2011, 04:37 AM
devis
I've experienced the same exact thing on my Infiniti J30. At close to 200k it started to behave like so... didn't pass smog, i was told to replace the O2 sensors. That, along with a tuneup brought it back to normal.
devis is offline
post #3 of 8 Old 04-10-2012, 01:51 PM
mybabyjasper
I've had the same problem in my 96, but I changed O2 sensors and the codes still keep coming back intermittently (changed spark plugs, wires, tailpipe, checked cat)
mybabyjasper is offline
post #4 of 8 Old 04-10-2012, 05:47 PM
FrankU
Had a similar problem with a Chevy Suburban. It ended up being the wires.
04 WJ 4.0, OME Kolak 3" lift, Addco's F&R ,18" JK Sahara's
FrankU is offline
post #5 of 8 Old 04-10-2012, 06:05 PM
wjjeeplkstevens
I had a similar issue on my jeep a when i first got it, could not find the source of a misfire on cyl 7 code. After I finally gave up replacing things myself (plugs, coil packs, fuel injectors etc.) i took it into the shop and after doing a compression/leak down test they determined it was a burnt valve... a full head job and $1500 later she purred like a kitten again (not that it really ran that rough before, just a slightly rough idle and the check engine light...) I hope this is not your case, but i thought i would throw that out there anyway...
2001 WJ - 5 / 4.5 inch lift- Clayton coils, IRO long arms, IRO Rear Adjustable A-arm and lowers, Bilstein 5125 shocks, ADDCO 684 Sway bar. Carolina Driveline double cardan conversion rear DS 255/75/17 BFG MT KM2's on Rubicon Rims. K&N CAI, 04 HO Intake Manifold, 3 in y-pipe back exhaust. 55w HIDs. JL audio upgrade
wjjeeplkstevens is offline
post #6 of 8 Old 04-10-2012, 06:49 PM
mybabyjasper
Kj
Oh dear God I hope not, but it's looking like I'll have to take it in. A similar thread said check the PCM and there's a YouTube vid for how to fix it... That'll be my first (sixth) check, then it's to the shop (luckily we have a jeep specialty shop by me called No Excuses).
post #7 of 8 Old 10-10-2012, 07:30 PM
dielawn
What ended up being the problem?
99 WJ used for pulling gear!!!
www.reverbnation.com/rituals
dielawn is offline
post #8 of 8 Old 10-10-2012, 11:24 PM
mybabyjasper
Mine ended up being a cylinder/valve problem. With it being a 96 and given me such a good run, I'm not spending the $2G to fix it. Small issue, too much labor to get to :-(
Good luck OP
4.7 misfire Ttech040 WJ Grand Cherokee Forum 3 02-20-2011 08:09 PM
WJ 4.7 Misfire skeletor88 WJ Grand Cherokee Forum 7 01-24-2011 02:30 PM
02 4.0 WJ misfire Blktjsport WJ Grand Cherokee Forum 1 09-06-2010 01:02 AM
Another misfire (4.7L) adipietra WJ Grand Cherokee Forum 2 05-30-2010 06:48 AM
4.7 misfire wee_____man WJ Grand Cherokee Forum 3 05-12-2010 10:10 PM
