Random engine cutouts - JeepForum.com
post #1 of 19 Old 05-05-2011, 01:55 PM Thread Starter
justn
So this first happened about a week ago. I was driving to work, and stopped at a light and my engine died. It started back up just fine and has been fine until today.
As I was accelerating (around 35-40 mph) my engine stalled and started back up again by itself 3 times.
All of this happend with I had my AC blower on high if that might have something to do with it.
I have a 4.0 2000 with around 108,000 miles on it. Where should I start my troubleshooting?
justn is offline
post #2 of 19 Old 05-05-2011, 08:44 PM Thread Starter
justn
Anyone?
Its also been really warm today, up into the 90s. Don't know if that could have anything to do with the engine stalling.
justn is offline
post #3 of 19 Old 05-05-2011, 09:05 PM
steveridesli
something like this was happening to my nissan.
found out my positive cable off the battery got melted by the headers and was grounding out there. probably not the cause but its an idea
4 inch RC-X + 2 inch BB
32 x 11.5 BFG MUDS
15x8 Soft 8's
Mudered Out
steveridesli is offline
post #4 of 19 Old 05-06-2011, 10:20 AM Thread Starter
justn
I took a look under the hood, and the battery cables seemed fine. The battery terminals were a little messy, but not really corroded messy, more like gunk/grease messy.
Anyone else have any ideas?
justn is offline
post #5 of 19 Old 05-06-2011, 10:26 AM
RedlegWJ
They pretty much need to be cleaned spotless, regularly on a WJ.
RedlegWJ is offline
post #6 of 19 Old 05-06-2011, 10:28 AM Thread Starter
justn
Ok good to know. I didn't know if the gunk was like a conducting goo or something. I'll take a wire brush to the battery terminals.
justn is offline
post #7 of 19 Old 05-06-2011, 11:20 AM
steveridesli
is your engine light on? try the key trick (flip key from off to on position quickly 3 times, then look at odometer) look the codes up on wjjeeps.com if there is any
32 x 11.5 BFG MUDS
15x8 Soft 8's
Mudered Out
post #8 of 19 Old 05-06-2011, 11:40 AM Thread Starter
justn
Check engine light isn't on, and it doesn't give me any codes.
Question about cleaning the battery terminals, its it ok to disconnect the leads without a 'memory keeping device'?
justn is offline
post #9 of 19 Old 05-08-2011, 03:51 PM
xxxxxxxxxxxxxxxxxxxxxxxxWThorn
Guest
yeah....it'll "relearn" itself and you probably won't have it disconnected long enough to matter anyways
xxxxxxxxxxxxxxxxxxxxxxxxWThorn is offline
post #10 of 19 Old 05-08-2011, 04:02 PM
volvite
Your best way to clean is to disconnect and use a wire brush to clean and have a shiny metal look. Also clean the terminals on the battery. Use a wire brush on those as well.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #11 of 19 Old 05-09-2011, 01:37 PM Thread Starter
justn
Alright, I cleaned the terminals so we'll see how the stalling goes. I noticed that the negative terminal was loose before I even got to it, so I made sure to tighten that up.
justn is offline
post #12 of 19 Old 05-09-2011, 02:30 PM
volvite
Nice. report back on what happens with the WJ.
volvite is offline
post #13 of 19 Old 05-18-2011, 02:29 PM Thread Starter
justn
Alright, it has stalled(ish) 3 times since the battery terminal cleaning and tightening. (The reason I say ish, is because it didn't completely die, causing me to restart the engine).
Once happened when I was making a left hand turn the engine stalled(ish) for a moment, but didn't completely die. It felt like it downshifted and then shifted back up within a second.
Today It stalled(ish) twice while driving around 55 mph. When it did it, it felt the same as described above.
I don't know if this is related, but my ABS light is on now too.
justn is offline
post #14 of 19 Old 05-18-2011, 02:47 PM
UPJeepster
Haven't had this problem on my WJ, but a friend of mine had a very similar problem on an older BMW. It would intermittently stall (mostly when going around turns and stopping). Turned out the wires going to the fuel pump had become a little loose/dirty, causing it to stall on abrupt movements.
Might be kind of a long shot, but thought I would mention it because it is an easy thing to check.
UPJeepster is offline
post #15 of 19 Old 05-18-2011, 11:30 PM Thread Starter
justn
I'll check that out UPJeepster.
So, tonight it started, and then instantly died. Then it took it probably a good 15-20 seconds of cranking to start back up again.
justn is offline
Random Chimes, no light ChiliFrei64 WJ Grand Cherokee Forum 27 01-12-2013 08:34 AM
Random Misfire - What else can i fix!? enjoithis WJ Grand Cherokee Forum 7 10-10-2012 10:24 PM
Random leak? dafox WJ Grand Cherokee Forum 0 04-06-2011 07:31 AM
two random questions greta WJ Grand Cherokee Forum 4 03-08-2011 07:35 AM
