Radio help needed. - JeepForum.com
post #1 of 6 Old 03-07-2013, 01:21 PM Thread Starter
Jeep32
Wj Radio help needed.
Hello Jeep Forum,
I have a '02 Jeep Grand Cherokee Limited with the upgraded stock radio but with aftermarket speakers. it has developed a problem where when I am accelerating the radio static’s away. When I first start the Jeep same problem. Radio goes almost dead with static when this happens. Does not do this when off but in accessory. oh yea, doesnt matter if its on am/fm/cd/cd changer
"so i did a full tune up soup to nutts."
4.7 213k+
Jeep32 is offline
post #2 of 6 Old 03-07-2013, 03:35 PM
pdpunome
Originally Posted by Jeep32 View Post
Hello Jeep Forum,
Make sure everything is grounded. There are instances where the engine ground strap breaks and causes static.
2000 4.0 Selec Trac
pdpunome is offline
post #3 of 6 Old 03-07-2013, 04:37 PM
its-me-B
triple check all your grounds...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #4 of 6 Old 03-07-2013, 07:22 PM
wjguru86
I no understand. when you accelerate the static goes away? when you start the start the jeep theres static? the radio goes dead with static? it doesnt do it when the radios off?
Agreed with checking grounds. try making your own grounds for the radio and amp. if there is a bad factory ground this will fix that. If new grounds do not correct the problem it is most likely a failing component. either the radio or amp.
wjguru86 is offline
post #5 of 6 Old 03-08-2013, 05:54 PM
dsodko
Wj Grounds
Factory Service Manual states there should be a ground from the exhaust pipe to the cross member to the transmission/transfer case page 8-16,17 V8. Also two studs on the intake manifold are grounded to the firewall for radio static suppression !
dsodko is offline
post #6 of 6 Old 03-08-2013, 05:58 PM
dsodko
Wj
Have you pulled the radio from the dash to check for a ground from the radio to the frame ? It could be loose.
dsodko is offline
