Radiator differences? - JeepForum.com
post #1 of 31 Old 07-21-2014, 01:18 PM Thread Starter
turbo224
I'm pretty sure my jeep was just built to leak coolant. After replacing the heater core, hoses, water pump, and thermostat all on separate occasions, the radiator finally let go. My question is whether there are different thicknesses of radiators from the factory. Was there ever a heavy duty cooling option or something like that? All the replacement radiators I see on line are single row units, so I just wanted to make sure I'm ordering the correct radiator. I have a 2002 GC limited with the 4.7.
turbo224 is offline
post #2 of 31 Old 07-21-2014, 01:22 PM
Cleaner13
I "think" and Im sure Im wrong, but Im assuming there would be about 4 radiators, 2 for each engine and the difference being whether it has the tow package or not.. I believe the tow package adds a transmission cooler...
2001 WJ Limited NV247 4.7
2008 KK Limited MP253 3.7
2008 WK Limited NV245 3.0 CRD
Cleaner13 is offline
post #3 of 31 Old 07-21-2014, 01:35 PM
MuddyWJ
All engine types had one radiator for each. Tow package added a mechanical fan. The only HD radiator would be an all aluminum. Griffin is the only brand I know of that makes one.
MuddyWJ is offline
post #4 of 31 Old 07-21-2014, 02:26 PM
Jeeples
Jeeples's Avatar
There's several vendors for one piece all aluminum two core radiators on eBay now. They're selling for roughly $200 shipped.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 31 Old 07-21-2014, 03:45 PM
MuddyWJ
Do we know if anyone has used said radiators? That's half the price of the Griffin.
MuddyWJ is offline
post #6 of 31 Old 07-21-2014, 07:41 PM
Cleaner13
Im not saying your wrong, but my jeep came with a transmission cooler and hydraulic fan...
post #7 of 31 Old 07-21-2014, 08:29 PM
DeChache
2003 WJ
I'm having trouble finding them do you have a link? I only see 2 row for a ZJ
I would also be interesting in knowing that I may be interested in one.
His 2003 Limited 4.7 QD 151 K
Hers 2008 Laredo 3.7 QT1 131 K
DeChache is offline
post #8 of 31 Old 07-21-2014, 09:10 PM
akoutdoors1
akoutdoors1 is offline
post #9 of 31 Old 07-21-2014, 09:32 PM
MuddyWJ
Some 4.7s came with a hydraulic instead of a e-fan. If you have a visible trans cooler it's aftermarket. WJs trans coolers are built-in to the radiators.
MuddyWJ is offline
post #10 of 31 Old 07-21-2014, 10:07 PM
Fellows45
are you sure your not looking at the power steering cooler? Because I'm pretty sure the trans cooler mounts on the other side of the PS cooler.
2002 Jeep WJ, 4.7, EBC Stage 4 brakes, Bilstein shocks (Still In progress)
1989 Wrangler YJ 2.5, 2 inch body lift, 33 inch tires
Fellows45 is offline
post #11 of 31 Old 07-21-2014, 10:21 PM
DeChache
2003 WJ
Originally Posted by akoutdoors1 View Post
Wow 150 to ship that sours the deal...
DeChache is offline
post #12 of 31 Old 07-21-2014, 10:38 PM
MuddyWJ
That's how fleabay works. 89 but $3000 to ship.
MuddyWJ is offline
post #13 of 31 Old 07-21-2014, 10:53 PM
Jeeples
Jeeples's Avatar
Here ya go:
http://m.ebay.com/itm/251316913505
Link says 99 & 00, but it should work for all years.
Jeeples is offline
post #14 of 31 Old 07-21-2014, 10:55 PM
Jeeples
Jeeples's Avatar
I don't think anyone here on JF has yet. I was prepared to be the guinea pig but it turned out my coolant leak was from my lower radiator hose.
Jeeples is offline
post #15 of 31 Old 07-21-2014, 10:59 PM
Jeeples
Jeeples's Avatar
No. The non-hydro fan 4.7's have a factory trans cooler option that mounts on the passenger side of the radiator. On the driver's side mounted to the front crossmember is a little single row PS cooler.
When they made the switch to the hydro fans the external trans cooler was no longer an option on the 4.7 as the new fan setup required the use of a larger PS cooler, which is mounted in the same place as the optional trans cooler on the older 4.7's.
Jeeples is offline
