Quick question about wheel width - JeepForum.com
post #1 of 3 Old 10-10-2013, 07:10 PM Thread Starter
golfinWJ
I'm about to order my 3 inch lift and a set of jegs d window steel wheels (16x8) with 4 inch's of backspacing. I'm going to put the tires I already have on my jeep which are 235/70/16 for a little while until I get new tires. Will it be a problem putting this size tires on that wide of a wheel? And...the maximum width tire that my jeep will see is most likely a 265 so do need a 8 inch wide wheel or just a 7 inch wide? I've tried searching the whole wheel width pros and cons but couldn't find anything for some reason.
golfinWJ is offline
post #2 of 3 Old 10-10-2013, 10:09 PM
3Dog
3Dog's Avatar
7 inch would work well. Check out the Specs section on Tirerack tire reviews. They will list both a range for wheel widths, as a well as the width of the tire.
3Dog
2015 WK2 Overland Hemi ORA II
2000 WJ Limited 4.7L
(IRO 3" Lift, Bilstein 5100s, 3/4" KOR front spring spacers, IRO adj. track bar, stock Silverblade rims in matte black powdercoat, 245/75/16 Goodyear Duratracs, Akebono caliper upgrade, OE armrest cracks...)
3Dog is offline
post #3 of 3 Old 10-11-2013, 12:52 PM Thread Starter
golfinWJ
Thank you, I found all the information I needed on Tirerack. It looks like I can use either width wheel for my stock tires and my next set of tires.
golfinWJ is offline
