quick DW advice - JeepForum.com
post #1 of 18 Old 07-20-2010, 01:29 AM Thread Starter
marcua56
quick DW advice
I went out today and explored some new land they cleared out for a house. Flexed around a little bit but did seem to get high centered once in mud. Aft er that about a hour later i tried driving on the interstate and nearly lost control and went off the DW was so bad. I could barely make it the 5 miles home. I would just violently shake till I slowed down enouh for it to stop. I added OME HD coils and mx-6's a month ago and everythings been great till now. My question is I know A steering stabilizer will help alot, but is could this be the cause of the sudden dramatic change? Is there anything else I should check first? The tires look good, just the stock 245/70/16. Most of the bushings i can see seem ok but I couldnt inspect to close. Im moving to colorado on aug 18th so im under a tight schedule.
Thanks in advance for any help
Tony
marcua56 is offline
post #2 of 18 Old 07-20-2010, 01:31 AM
sandman
check the track bar.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 18 Old 07-20-2010, 02:00 AM
lateralus3
1994 ZJ
what about mud on the inside of the rims?
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #4 of 18 Old 07-20-2010, 05:34 AM
Apollo21
TREs?
and an SS won't help if your running stock tires. Your stock SS is fine for that
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #5 of 18 Old 07-20-2010, 09:07 AM Thread Starter
marcua56
Ok i wasnt sure if I blew out the SS somehow offroad and thats what caused it. I got a car wash after I got off the interstate the first few times It happened on the interstate and It still went about 5 or 6 times on the way home.
marcua56 is offline
post #6 of 18 Old 07-20-2010, 12:14 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The steering stabilizer cannot cause DW. In reality, you dont even need a steering stabilizer. It is just a shock to make your steering feel smoother. Just like you dont really need shocks since the springs are what hold the jeep up. But without them, it would make for a hell of a rough ride.
Check your tie rod ends (all 4) and your track bar. Do you still have the stock track bar?
~James
ezflip is offline
post #7 of 18 Old 07-20-2010, 01:38 PM Thread Starter
marcua56
Yes still Using the stock track bar. I got under her today with a power washer and mader sure there was not left over mud. Took it for a spin and it did it twice in a 50 mile drive so its at least semi driveable. Im guessing tie rods will be the next to check out. Any tip or suggestions?
marcua56 is offline
post #8 of 18 Old 07-20-2010, 01:39 PM
ZJ5point2GCL
Check the track bar and TRE's, possibly even a bent rim?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #9 of 18 Old 07-20-2010, 06:10 PM Thread Starter
marcua56
checked the track bar. and it seems to wiggle on the passenger knuckle side. Is thois correct?. I dont think it is so im going to go take the cotter pin out and try to tighten it. Checked the tie rod and it seemed to be super secure. Other then that im starting to get lost.
marcua56 is offline
post #10 of 18 Old 07-20-2010, 06:16 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I really hope you mean drag link. Your track bar goes from the frame on the drivers side and mounts to the axle on the passenger side. There better not be any cotter pins on that and it better not wiggle at all.
The drag link should have some rotational play, but if you can move it left-right or up-down, that is bad.
~James
ezflip is offline
post #11 of 18 Old 07-20-2010, 06:51 PM Thread Starter
marcua56
I checked the trac bar. One castle nut was loose so I tightened it. Now theres no side to side movment it just rotates along the join. Is there anything else I should check for on it. And how should I go about testing the TRES
marcua56 is offline
post #12 of 18 Old 07-20-2010, 06:53 PM Thread Starter
marcua56
I was checking the bar that seems to come off of the idler arm? Sorry iv very confussed under SFA vehicals. Im used to lowered imports
marcua56 is offline
post #13 of 18 Old 07-20-2010, 07:09 PM Thread Starter
marcua56
now that I got whats what under control I got back underthere and check the trackbar. No luck, seemed very solid in every direction.
marcua56 is offline
post #14 of 18 Old 07-21-2010, 10:00 AM Thread Starter
marcua56
Are the TRES the joints that connect the drag link to the passenger knuckle if so Im thinking this may be bad.
marcua56 is offline
post #15 of 18 Old 07-21-2010, 11:44 AM
sandman
yes, well technically thats a drag link end but same thing. you have 4 of them the drag link connects to the passenger nuckle and the steering box, the tie rod connects to the drivers side nuckel and the lower part of the drag link, if any of those are bad, you could get DW, remember rotational play is normal anything else is not.
1993 Jeep ZJ. 4.0
sandman is offline
death wobble , steering wheel shimmy
quick trip to the dealer turned into a nightmare...need advice! Chazzino ZJ Grand Cherokee Forum 17 06-05-2010 09:42 AM
Rear Axle advice... QUICK Max-Bilt ZJ Grand Cherokee Forum 11 02-16-2010 01:44 PM
Quick Quick Quick....Front DS U Joint Removal Darthteddy ZJ Grand Cherokee Forum 3 08-11-2008 12:25 AM
231J/247 TC conversion.. quick,quICK,QUICK! UUJ1 ZJ Grand Cherokee Forum 7 05-25-2007 08:20 PM
Need quick advice for diff fluid needacherokee ZJ Grand Cherokee Forum 6 01-25-2006 02:29 PM
